Race tech emulators - Page 3
Results 21 to 30 of 38
Like Tree62Likes
Thread: Race tech emulators
  1. #21
    Senior Member ben2go's Avatar
    Jan 2016
    Upstate,SC USA
    206
    Quote Originally Posted by jb882 View Post
    Have you read the tuning guide? Emulator Tuning Guide
    the reason i ask is i personally have not seen any setup guide for any specific bike for these. They are basically universal for any bike that they fit. when i did mine i had to do a lot of testing and tuning to get them where i wanted them. It was worth the effort. Put them in, ride it and make adjustments based off the guide and what you are feeling. I don't think there is any magic pill for settings given that every rider is different.
    I haven't seen much Racetech instructions on most bikes but on my Katana 750 forks I installed on my GS500, the instructions thoroughly explain where to drill and weld the OE damper rods so the emmulators work properly. I guess with them, it comes down to which bike and the difficulty of the install.
  2. #22
    Senior Member Lyterx's Avatar
    Jun 2014
    Etters, Pa
    471
    Does anyone have the part# for these?
    1991 TW200
  3. #23
    Jul 2012
    Wet-ern Washington
    1,394
    Quote Originally Posted by Lyterx View Post
    Race Tech Gold Cartridge Emulator FEGV 3301 (33mm)
    On Amazon here... https://amzn.to/2F9Bx3J
    Tweaker, Badgerflorida and Lyterx like this.
    - Leisure Time Larry -
    2004 TW200, 13-54 gearing, Shinko 241, Race Tech Emulators, Procycle front springs, Works Performance rear shock, Emgo handguards, Luckybike mirror risers, Ken Sean DS foldable mirrors, 30mm Tusk bar risers, Seat Concepts, Kick Starter kit, Plasti-dip camo coat, Cycle Pumps, Ricochet Skid Plate, flood and spot LED pod lights, Sena, Garmin etrex 20 GPS, IMS 313114folding shifter
  5. #24
    Jun 2014
    Etters, Pa
    471
    Quote Originally Posted by Leisure Time Larry View Post
    Thanks Larry, this is going to be next on the list of things to do.
    1991 TW200
  6. #25
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    If you call Race Tech and ask for support, give your bike, your weight (along with any additional load you want to carry) they will give your pretty good specifics on how to set them up. They did for me...
    Tweaker, Lyterx and ben2go like this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
  7. #26
    Jun 2014
    Etters, Pa
    471
    Quote Originally Posted by JerseyJeeper View Post
    So what did they tell you?
    1991 TW200
  8. #27
    Mar 2011
    3,880
    Don't go by mine. Everyone weighs and carried different stuff but here it is:
    Darth likes this.
  9. #28
    Member BUMBLESPECIMOODA's Avatar
    Sep 2018
    OSHAWA
    89
    So, does one have to drill out the flow holes for more flow, or can ya just install them emulators under the main springs and go?
  10. #29
    Jul 2012
    Wet-ern Washington
    1,394
    No, you have to drill. The point is that the emulator will replace the holes in the damper rods for dampening duties. The reason the dampening is crap normally, is the holes are too restrictive. Therefore, you must drill out the dampening holes to allow the fluid to get to the emulator so it can do the dampening.
    JerseyJeeper likes this.
  11. #30
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,507
    No,must be drilled...per exact instructions! Not drilling would totally screw the pooch....did you read their instructions?
    Read all this thread (above) and it should come clear.
    You might find a local Scrambles racer or enduro rider who has a room full of trophies and get him to help you.
    Or, call Race Tech with very specific info on your bike & weight, where & how you want to ride and don't blow smoke about how good you are.
    He will know what you need to do, including oil viscosity & level.
    If you don't want to fool with it, find a local shop that does suspension work for dirt bikes and let them do it...piece o' cake for them!
    They will probably call Race Tech for specifics.
    You might also replace the rear OE spring, even if new. Anytime you fix the suspension on one end of a bike, it will magnify any weaknesses on the other end. Pro Cycle has the spring in two strengths. They are good and will balance the bike out. I think they are also made by Race Tech but not sure.
    I have Emulators and their front & rear springs on my bike....a really sweet, balanced package. My suspension no longer feels like the bottom shelf package it is (was).
    Do it right, do it once...and let us know how ya make out!
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
  1. Race tech fork cartridge emulators and springs
    By Deepseadan in forum Technical Help
    Last Post: 08-27-2017, 11:14 AM
  2. Gold Valve cartridge emulators
    By Rhodetrip in forum TW200 Classifieds
    Last Post: 06-12-2016, 01:58 PM
  3. Race Tech Cartridge Emulators & OEM Turn Signals
    By Jut8 in forum TW200 Classifieds
    Last Post: 12-22-2015, 07:48 PM
  4. motorcycle race
    By arrowsmith in forum Off-Topic
    Last Post: 11-03-2014, 10:39 AM
  5. So I entered a race...again
    By Rainman in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-19-2013, 08:15 PM
