Race tech emulators - Page 4
Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Like Tree62Likes
Thread: Race tech emulators
  1. #31
    Member BUMBLESPECIMOODA's Avatar
    Sep 2018
    OSHAWA
    87
    I kinda knew I had to totally go in these forks, but I asked the lazy question anyway. Thanx again guys.
    Darth likes this.
  2. #32
    Hailey, ID
    3,164
    When you start drilling, be aware that there are some directions out there that specify four holes...drill out the original two and add two more. This is NOT necessary and is pointless extra work on a TW. Just drill out the original holes to 1/4 inch, deburr and carefully clean out cuttings before re-assembling.
    And, yes, it's all worth it.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  3. #33
    Sep 2018
    OSHAWA
    87
    I was aboot to ask that question. Thanks. I'll just enlargen the 2.
  5. #34
    Senior Member ben2go's Avatar
    Jan 2016
    Upstate,SC USA
    206
    Not drilling the rods for emulators would turn the forks into solid rods of pain. LOL
    Darth likes this.
  6. #35
    Sep 2018
    OSHAWA
    87
    I just found out there is a tool needed to remove the staction tubes. Anyone know where to get one?
  7. #36
    Sep 2018
    OSHAWA
    87
    Quote Originally Posted by BUMBLESPECIMOODA View Post
    Nevermind. Found out I just need a reall long 19mm allen key. LOL
  8. #37
    Senior Member nihil's Avatar
    Jan 2018
    233
    If you have a lathe, NAPA sells a 19mm hex head with 1/4" drive, but you have to turn down the O.D. a few mm to get it to slide into the fork tube. The bonus there is that it's dead centered every time you put it in there.
    `09 TW200
  9. #38
    Hailey, ID
    3,164
    Get a 3-5" long bolt to fit the 19 mm nut. Put 2 on and lock them as hard as possible against each other on the end with Locktite. Then use a regular 6 point metric socket and extension to get out far enough to put a 1/2 drive ratchet on.
    The damper rod is in there with some form of Locktite and it takes about 80-90 ft./lbs of torque to break loose, you will definitely need a 1/2 inch drive. This is the hardest part of the whole installation.
    JerseyJeeper likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Race tech fork cartridge emulators and springs
    By Deepseadan in forum Technical Help
    Last Post: 08-27-2017, 11:14 AM
  2. Gold Valve cartridge emulators
    By Rhodetrip in forum TW200 Classifieds
    Last Post: 06-12-2016, 01:58 PM
  3. Race Tech Cartridge Emulators & OEM Turn Signals
    By Jut8 in forum TW200 Classifieds
    Last Post: 12-22-2015, 07:48 PM
  4. motorcycle race
    By arrowsmith in forum Off-Topic
    Last Post: 11-03-2014, 10:39 AM
  5. So I entered a race...again
    By Rainman in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-19-2013, 08:15 PM
