Rear turn signal lights - should they be on all the time?
Results 1 to 5 of 5
    Junior Member tbrady's Avatar
    Sep 2012
    7
    Hi All,
    I just bought my first TW200 a few days ago. Does anyone know if the rear turn signal lights should be on all the time? The front ones are but the rear ones only come on with the turn indicator...
    thanks!
    tim
    Desert, SoCal
    7,369
    No.
    Do your tail anf brake lights work?
    Senior Member atleastbehandy's Avatar
    Apr 2011
    Toronto, Canada
    250
    My 2005 is the opposite: The rear lights are on all the time but the front ones are not.
    Edit: I must have been riding backwards! The fronts are on, the rears are not.
    2005 TW200, 2" PowerMadd bar riser, Tusk D-Flex Hand Guards, PowerMadd Hand Muffs, Kick-Start, Valco Cup Holder, Givi E45N Top Case, Inline fuel filter, Storage Tube with MSR bottle, 45 Tooth sprocket, Stebel Low Tone horn, #130 Main Jet / no needle shims / 1.5 turns out on idle, Jimbo Shield, DID O-Ring chain, Clarke XT250 4.1 Gal tank, Custom Cycleracks
    Sep 2012
    7
    No.
    Yes, the brake and turn signals work fine. I just thought it was odd that the front turn signal lights were on all the time but the rear ones were not...
    Thanks a bunch!
    Desert, SoCal
    7,369
    The front turns are also marker lights on all but '87 models. They carry 2-filament 1157 bulbs and have 3 wires. One filament is always "on" serving as marker lights, the other is for the turn signals.
    The rears function only as turn signals (in fact it's illegal to have amber showing in the rear unless the light is coming from a turn signal). They have single filament 1156 bulbs,and two wires.
    If you have anything else you have a wiring problem or some P.O. in the bike's history did something funky in the name of increasing "visibility".
  1. LED turn signal heads up
    By operose in forum Technical Help
    Last Post: 03-24-2012, 09:33 AM
  2. Rear turn signal extenders
    By dhoenisch in forum Performance and Customization
    Last Post: 05-02-2011, 01:23 PM
  3. Rear signal lights: turn signals only?
    By thal13 in forum Technical Help
    Last Post: 04-24-2011, 06:57 PM
  4. Vapor Turn Signal Kit Help
    By Justin5117 in forum Technical Help
    Last Post: 11-12-2010, 08:20 AM
  5. turn signal, right rear, "quick" flashing, good bulb
    By flybill59 in forum Technical Help
    Last Post: 09-12-2010, 09:46 PM
horn thal13
