Where does this cable go?
Results 1 to 10 of 13
Like Tree1Likes
Thread: Where does this cable go?
    Senior Member jannaruto's Avatar
    May 2017
    363
    My dad dismounted another TW we purchased, a cafe race one
    He removed this cable but forgot where to attach it, it is a TW125, also attached some carburetor photos so maybe you can identify the model
    Note we already connected the one near starter motor and back of the front part of the chassi, so is not that one
    Mar 2015
    Ynys Môn
    4,631
    The European TW125 has a carb heater ........
    Peterb likes this.
    - Hidden Content
    May 2017
    363
    The cables for the carb are already connected 😞
    May 2017
    363
    Little up
    Mar 2015
    Ynys Môn
    4,631
    Don't know a lot about the 125 I'm afraid
    That seems to be an earth cable - but to or from what, your guess is as good as mine
    - Hidden Content
    Feb 2013
    Missoula, MT
    908
    Attachment 166313
    Looks like an electrical connector, to me. The "slip" connector must go there and the round "lug" end must connect to power. This is NOT a ground (earth) cable. Look for a power connector close to the carb. I hope my altered photos show up.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,485
    Is it not the ground cable for the carb heater?
    Feb 2013
    Missoula, MT
    908
    Power has to come from somewhere. The carb should be grounded via bolts, etc. However, I am just guessing, too. I have a USA TW200. No carb heater and no 125's here.
    Mar 2015
    Ynys Môn
    4,631
    Fishguy - that point on the carb was my first thought, but I'm not sure that spare wire has a spade end - curious as to why you think it's not an earth though
    Peterb - the thought had crossed my mind, but jannaruto and his dad know what they're doing (kinda) - in the absence of a diagram for the 125 or any other experience of it for that matter, it has to be a "hands on" solution
    (Edit)
    The manual is here http://www.tw-parts.com/macbig2k1/doc/tw125-2002.pdf and predictably, about as much use as a chocolate tea cup
    Following this link https://tw200forum.com/forum/technica...-125-carb.html – post #3 – takes you to this link - https://www.yamahamotorcyclespares.c...?uID=812856335 – and if you ignore the “security issue” (it’s safe), then parts 25 and 26 do indeed refer to the carb heater
    Now, if the bullet end of that remaining cable matched up to the point on the carb comfortably, then at around 6 degrees temp, the sensor under the seat should send a signal to the carb heater, which makes that brass spade end either a positive or negative – depends if you can first prove that there is one other electrical connection to the carb, which would then make it a negative, provided the other wiring point is correct – but in any event, there should be something connected to that brass spade on the carb
    Feeling lucky ?
    - Hidden Content
    Jun 2017
    Milwaukee, WI
    1,293
    Check front mounting bolt of the regulator. Should be a cable just like that mounted via that bolt. Cheers
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
  1. Throttle cable
    By bad luck in forum Technical Help
    Last Post: 08-07-2017, 06:51 PM
  2. Speedo Cable
    By RTG in forum TW200 Classifieds
    Last Post: 04-10-2016, 11:27 AM
  3. Clutch Cable
    By wolfpack in forum Technical Help
    Last Post: 11-21-2013, 11:52 AM
  4. Coil Cable
    By tuhinuhi in forum Technical Help
    Last Post: 08-27-2013, 02:43 AM
  5. Need help with cable routing
    By Ayers Garage in forum Technical Help
    Last Post: 07-19-2012, 04:46 AM
