2011 TW won't start weirdly
Results 1 to 10 of 17
Like Tree16Likes
Thread: 2011 TW won't start weirdly
    Junior Member Kevinophoto's Avatar
    Jan 2018
    Honolulu, HI
    24
    Angry 2011 TW won't start weirdly
    This bike has been f*cked since I got it and I'm trying to salvage it.
    It won't idle, cleaned carb 4 times, spark is good and brand new spark plug, brand new gas, carb is properly set, valves adjusted, timing set perfectly check 5+ times.
    If you let the bike sit for 5 minutes, it will start right up and idle at like 5,000rpm. Usually will only start with throttle wide open. It will hold idle for 15-30sec, unless you let off the throttle a little then it will die.
    After the first start, you have to let it sit for roughly 5 minutes before it will start again.
    Took it to a mechanic, he doesn't have a clue either.
    Anyone heard of this before?
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Have you checked for air leaks using propane or similar? Have you REPLACED the original jets with new OEM jets?
    Senior Member Nicoradv's Avatar
    Mar 2018
    North East Texas
    167
    Sounds like he has at least two problems.
    1) air leak like you stated
    2) CDI or equivalent heating and going bonkers.
    OP have u check that you still have spark after its heated up and how far that spark will jump ?
    PlacerLode and Kevinophoto like this.
    If a bike is plated, it's suppose to be ridden, not hauled on a trailer.
    2002 DR650SE, 2001 TW200
    Feb 2013
    Missoula, MT
    908
    Ya, check for spark after engine is hot and will not start.
    PlacerLode likes this.
    Senior Member Dell's Avatar
    Aug 2012
    139
    You might be doing the wrong thing in the carb that many times. Bad gasket or something. But for variety, I’d go to ignition. See if your plug wire lead gives you a fat and happy, long jumping spark in the different situations you described. I hope it’s not a CDI problem, and as it seems to respond to temperature so fast, could it simply be the plug? I would imagine you’ve been there already....
    Nov 2010
    Frostbite Falls Ill
    2,719
    Hey Dell, why is the little bird pecking a hole in your hand?
    Phelonius
    Aug 2012
    139
    Winning the trust of that little lady to come in and turn off her motor for a drink of sugar water was one of the more important things I’ve done in a while.
    Member koolhandlinc's Avatar
    Feb 2018
    Tulsa
    89
    Immediately after it dies. Check plug for dampness. Does it still have strong fire when it dies?
    Kevinophoto likes this.
    TW200 number 2. 2018 1.1 miles when I picked it up.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    983
    Quote Originally Posted by Kevinophoto View Post
    Can you ride the bike? Have you actually ridden a tank of gas thru the bike? Does it run OK except for the idle issue?
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Senior Member arrowsmith's Avatar
    Missouri
    675
    clean the idle jet.the one at the front of the carb that we all adjust.
    admiral likes this.
  1. No electrical at all, won't start, will bump start
    By jgaff in forum Technical Help
    Last Post: 08-10-2017, 02:06 PM
  2. TW won't start.
    By JasonTX in forum Technical Help
    Last Post: 12-21-2016, 04:27 PM
  3. Won't Start - Lights all die when start engaged
    By vuldub in forum Technical Help
    Last Post: 09-14-2016, 10:39 PM
  4. Won't start but will???
    By Lido in forum Technical Help
    Last Post: 09-12-2011, 08:37 PM
  5. kick start won't start
    Last Post: 01-15-2011, 06:23 AM
