Opinions requested
Results 1 to 7 of 7
Like Tree7Likes
  • 2 Post By canyncarvr
  • 3 Post By Nicoradv
  • 1 Post By phelonius
  • 1 Post By Pete H
Thread: Opinions requested
    Member canyncarvr's Avatar
    Mar 2014
    State of Jefferson
    31
    Opinions requested
    From folks that have done it, it is said the top tapered roller replacement for the TW steering stem sits 'up' a bit. Would any consider this to be a problem? Does this fit 'above' damage the integrity of the installation and therefore, bearing usefulness?
    Given two options, I'd choose the top outer race to be a bit above the stem tube than below the stem tube. If it was below, that would be a great place for moisture to pool and cause problems.
    The right way for the bearing to sit is, well, in the right spot; neither below or above the tube, but in a way that allows the dust seal to have the best chance of doing its job. Apparently, that isn't something that needs to be considered.
    I've replaced steering stem bearings a handful of times in different machines. The tapered rollers I used in those cases always fit 'right'.
    The top of the stem isn't likely to be subject to a drenching downpour, to be submerged, or packed full of mud.
    I'm just asking for opines to be proffered. I know they're out there. It's been said that everybody has one.
    Thanks for yours!
    Ken and Smitty Blackstone like this.
    Senior Member Nicoradv's Avatar
    Mar 2018
    North East Texas
    167
    Quote Originally Posted by canyncarvr View Post
    Thanks for yours!
    the lower race/bearing fit fine.
    After i installed the upper race and put the rollers in there, I don't see any problem with it that way.
    buttoned mine back up after looking real hard at it and the way it went together, that top bearing is sealed from moisture still.
    I for see no regrets with this setup.
    I don't consider that top bearing to be load bearing, more of side to side and not much of that really.
    Ken, Tweaker and Old n dirty like this.
    If a bike is plated, it's suppose to be ridden, not hauled on a trailer.
    2002 DR650SE, 2001 TW200
    Nov 2010
    Frostbite Falls Ill
    2,719
    I am opinionated but I would agree with that.
    Ken likes this.
    Phelonius
    Senior Member Pete H's Avatar
    Dec 2016
    Upstate NY
    107
    If it exposes the bearings to weather or high pressure washes I would think it's a problem. I no longer use high pressure sprayers on any of my machines. back in the mid 80's I had a Suzuki SP500 duel purpose. Basically the grandfather to the DR 650. My buds and I all had DP bikes and regularly muddied them up, then took them to self serve car washes. I'm my third year of ownership I decided to tear it down, replace any missing fasteners, and paint the frame. I was horrified at what I found. both the steering stem, and swing arm bearings had trapped water. Surface rust was on all the bearings which had to be replaced. The bike had less than 12,000 miles.
    When replacing the rear spring on my 2008 tw I noticed just how dried and cracked the shock bolt seals were. I plan on doing a good tear down this year and replacing the dried up rubber products and using good quality waterproof grease. Hopefully I'll catch it before having to replace the expensive stuff.
    Old n dirty likes this.
    Mar 2018
    North East Texas
    167
    Quote Originally Posted by Pete H View Post
    It doesn't, provided he puts it back together right.
    That very bottom seal 3/8 in thick or so is reused. Hopefully its still pliable.
    Mar 2014
    State of Jefferson
    31
    The 'steering' IPB I looked at (partzilla..although all diagrams I've seen are the same) does not show the bottom seal. That part is in the 'forks' IPB. That seal fits on the clamp, NOT the stem. I didn't understand how the old seal could be used in addition to the kit seal and everything still fit properly. AllBAlls sent me the attached pic. Different diameters!
    The PN for that seal: 164-23462-00. It's available on the web.
    Mar 2018
    North East Texas
    167
    Put it back on anyway. That images shows exactly why i did put it back on.
  1. Gun guys -- input requested, please.
    By kj7687 in forum Off-Topic
    Last Post: 08-28-2017, 01:27 PM
  2. Hennessey hammock setup as requested.
    By Dryden-Tdub in forum Trails, Off-road, and Adventure Riding
    Last Post: 07-15-2017, 12:56 PM
  3. Paint job advice requested
    By Columbanus in forum Performance and Customization
    Last Post: 09-15-2016, 05:48 PM
  4. RBM some pics of my new truck as requested
    By jb882 in forum Off-Topic
    Last Post: 06-09-2014, 09:48 AM
  5. opinions and comments requested
    By thumper in forum General Discussion
    Last Post: 11-30-2010, 04:22 PM
