What is Hot for air cooled engines?
Results 1 to 6 of 6
Like Tree3Likes
  • 2 Post By Swingarm
  • 1 Post By jtstdub
Thread: What is Hot for air cooled engines?
    Senior Member Pete H's Avatar
    Dec 2016
    Upstate NY
    107
    I've got a spark plug ring temp sensor. Now the trail computer I've got says air cooled engines read hotter than liquid cooled. But it doesn't say how hot is dangerous. I also know that under the plug is probably the hottest point in a air cooled cylinder. All I know is 260 to 300 is normal at trail speeds and upwards of 340 occurs at 55 to 60mph road speeds prolonged for very long. It never seems to act hot as far as metal "tinking" goes, but I also know that those temps in a liquid cooled engine are catastrophic. Does anyone have any "rule of thumb" on this sort of thing?
    Thanks,
    Pete
    Senior Member Swingarm's Avatar
    Jan 2017
    Houston Tx
    135
    Interesting question so I looked around and found this thread. It doesn't seem like you have any problems at your temps.
    Cylinder head temperature on air cooled engines | Adventure Rider
    littletommy and Pete H like this.
    Senior Member Tjmay's Avatar
    Jan 2018
    Destin Florida
    234
    Very interesting thread. Thanks for posting that.
    I too worried after installing a Vapor Trail that had a spark plug sensor. I’ve had it for a month now and find that i don’t look at it every few minutes like I did at first.
    Under load, I see temperatures of 320 to 340. But, now I dont worry about it.
    May 2013
    Groton, NY
    2,663
    I don't have any gauge for head temp., I don't want to know what it is. On a hot summer day, after paddling through deep mud in 1st gear for a half hr. with the cooling fins plugged up with crud, I might not want to do it again if I knew the temp.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Jan 2015
    Fair Oaks, Calif
    503
    Cool days around 275-300... Hot days running around town etc 325-340 is what I see... I too have the Vapor Trail. The temp reading is taken from the spark plug to head so that is a real hot spot.
    Jim
    Pete H likes this.
    Dec 2016
    Upstate NY
    107
    Hey all,
    I'm glad I'm not the only one seeing these temps from the Vapor trail tech. Thanks for the feedback.
  1. Winter Riding: Air Cooled but Liquid Fueled
    By Fred in forum Off-Topic
    Last Post: 01-07-2018, 08:39 PM
  2. Air-Cooled vs. Water-Cooled Survey
    Last Post: 09-25-2015, 06:00 PM
  3. Kawasaki Open Class History - Part 1 The Air Cooled Years
    By littletommy in forum Other Bikes
    Last Post: 07-24-2015, 11:55 AM
  4. Speeds from 200 cc engines
    By Polarpilot in forum General Discussion
    Last Post: 03-10-2012, 10:09 PM
  5. Pictures of the XT, BW, and TW engines?
    By TonyM in forum Technical Help
    Last Post: 01-22-2011, 02:20 PM
