Am I asking to much from the TW's electrical system
Results 1 to 9 of 9
    Member hooker's Avatar
    May 2012
    Wet side of the mountains, Washington State
    30
    Howdy All,
    Winter is soon to be here, I ride all year around and have heated grips on all my bikes. I just last night with the help of a friend who knows his way around wires installed a set of Hot Grips, on my 2010 TW 200. The grips get warm on low and hot on high but when they are on the head light is not as bright as when they are turned off and it doesn't get any brighter when the engine is revved up. The bike only has 650 miles on it, I bought it a few months ago with 39.7 miles on, it was checked out by a local dealer so the extended warranty could be switched over to me so as far as I know everything is OK in the electrical system. So I guess my question is this, will the stock electrical system on a 2010 TW support running a set of heated grips and not run down the battery or ruin the electrical system? Thanks for any information you can share.
    ALL brand motorcycle lover and rider, long distance cross country rider, logging road and two track rider, year round sidecar rider. I have been told since young to grow up and act my age, I ain't doin it, I am too busy living my life even if it kills me. Visit my photo web site, ( Hidden Content )
    Aug 2011
    Cayce, SC
    3,109
    Because of the electrical systems limited capabilities, you may want to switch your brake and signals to leds to offset the pull from the grips.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Stanwood,Wa
    1,880
    Welcome back Mr. Cob. Here is some info I found. Looks like you may need to change out your bulbs to led to free up some watts.
    https://tw200forum.com/index.php?/top...__1#entry12803
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    May 2012
    30
    Howdy PalmStateCrawler, goldenthr,
    Thanks for the information and the link. Now I'll have to do some research on led bulbs. I have also been thinking of just putting a switch on the head light and turning it off for when I am riding off road, I did that on my DRZ and it sure helped with battery drain.
    Senior Member rm_hm's Avatar
    1,619
    If you did the handlebar cig lighter outlet mod, you could plug one of those portable voltmeters in. Or hardwire one to the bike. You would know in a sec if you were loosing ground.
    May 2012
    30
    Quote Originally Posted by Rich View Post
    Howdy Rich,
    Thanks, I did wire a cig lighter outlet in so I could use my small air compressor so it would be easy to use the plug in voltmeter you have shown. Thanks for the info.
    Senior Member Dubster's Avatar
    Nova Scotia Canada
    583
    09 DL650 V-Strom "Function over Form at a Superior Price"
    09 DR650 "Hooliganizer"
    03 TW200 "No Road---No Problem"
    81 Z50 "Just Because"
    98 Honda Valkyrie "Fast as [email protected]&K"
    02 Tw200 " Camouflaged Redneck Edition" Sold to Son-in-Law
    73CT Trail90 "The most fun you can have under 100cc's" Sold. Had an offer I couldn't refuse.
    Apr 2011
    Martinsville Indiana
    2,089
    You could go with an hid headlight and gain 20watts. I ran a 24 watt heated vest on mine with no problems but i do have the 35watt hid headlight. I want to put a set of heated grips on mine but i would only run them on low. I run two 21 watt leds along with the 35 watt headlight at night and it holds 14+ volts even at idle. How many watts/amps do the grips pull at each setting?
    May 2012
    30
    Quote Originally Posted by Small's View Post
    Howdy Small's,
    I am an electrical idiot, it probably said someplace on the instruction how much juice the grips pull but I don't remember what it was.
  1. Charging system
    Last Post: 02-10-2013, 09:32 PM
  2. Battery/charging system
    By swimmer in forum Technical Help
    Last Post: 09-21-2012, 03:11 PM
  3. Charging system output
    By TWMike in forum Performance and Customization
    Last Post: 05-12-2012, 08:23 AM
  4. Battery Charging System?
    By DBuck42 in forum Technical Help
    Last Post: 03-30-2012, 02:30 PM
  5. Short in the system
    By RisingSun in forum Technical Help
    Last Post: 02-05-2012, 06:48 PM
emgo travel trunk
emgo travel trunk v strom
heated grips
tw200 airhawk seat
tw200 headlight upgrade
tw200 long distance
yamaha tw200 round headlight
