What is this junk on my front brake cable?
Results 1 to 10 of 13
Like Tree23Likes
Thread: What is this junk on my front brake cable?
    Junior Member captainkevman's Avatar
    Jan 2018
    4
    Previous owner did something funky to the front brake cable where it attaches to the drum arm.
    What is it? Why would he do that?
    How do I get rid of it?
    Feb 2015
    Maple Ridge, BC, Canada
    1,594
    Looks like some type of cold weld material.
    Probably put on as the mount was cracked or broken.
    Not sure you want to get rid of it if the front brake is working.
    Jan 2018
    4
    front brake is working but I'm not seeing an easy way to remove the front wheel with this stuff on there and it's new front tire time.
    Ken likes this.
    Sep 2014
    Mamaroneck, NY
    2,196
    So, slide the tire out, remove the backing plate and let it hang (check the brake shoes) , then remove the old tire and reinstall the new one.
    ejfranz, Fred and Ken like this.
    Feb 2015
    1,594
    With the bike on a stand, will not the wheel drop down enough once the axe is removed to allow the hub to pull out of the wheel so that you do not have to remove the "weld".
    At some point you may have to deal with, as in the brake cable breaks.
    Do you have a Dremel to grind the "Weld" into the proper shape of the bracket?
    Ken likes this.
    Mar 2015
    Ynys Môn
    4,637
    When it comes to “new front tire” time, you can still remove the front wheel without “disturbing” whatever it is that you have got going on under there
    Personally, I think that it adds a certain amount of “mystic” to the proceedings, but I’d recommend carrying a spare cable just in case …..
    Welcome to the madness ….
    Ken and ejfranz like this.
    - Hidden Content
    Jan 2018
    4
    I do have a dremel that I like working with. I figured that's what was going to happen next. Would anyone kindly post a picture of what it's supposed to look like?
    Dec 2017
    Western Washington
    217
    One thing to keep in mind is that if that cable support fails you will lose all braking at the front wheel. That’s the majority of your stopping power. If it was me, I’d start searching for a new front brake backing plate. They cost $61.00 on boats.net. Good luck.
    3Y1-25121-01-35 YAMAHA PLATE,BRAKE SHOE
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400’s, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    Jan 2018
    4
    Gastone, I think you're right, I haven't dug into it yet, but IMHO why else would it be covered in what looks like JB Weld or an epoxy if not to keep that cable support from breaking more. Nobody would goo that up unless they had to, so I'm assuming the previous owner broke that at some point and kinda glued it back together. Thanks for pointing me to the right part so quickly.
    Dec 2017
    Western Washington
    217
    Good to hear you’re going to use a new part. At $61.00 plus shipping it’s less painful than I thought it would be.
    There’s nothing like grabbing a handful of front break in an emergency and not finding any. 😳🚑
    If you order it off boats.net be sure to verify your year and hub color. I wasn’t able to do that when I attached the link.
    Smitty Blackstone likes this.
  1. I’m search of front brake cable.
    By spewingjason in forum TW200 Classifieds
    Last Post: 12-14-2017, 05:58 PM
  2. Front Brake cable Stretch?
    By Ukdave in forum Technical Help
    Last Post: 11-22-2016, 04:26 PM
  3. Front brake cable?
    By cmercon in forum Technical Help
    Last Post: 07-07-2014, 09:12 AM
  4. Front brake cable/lever?
    Last Post: 11-09-2012, 03:37 PM
  5. Front brake cable/lever?
    Last Post: 11-09-2012, 02:48 PM
Tags for this Thread
