Throttle cable question
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By dman33
Thread: Throttle cable question
    Member dman33's Avatar
    Sep 2017
    SOUTHEAST IDAHO
    49
    All of my 2 stroke bikes have a single throttle cable and a spring returns to a closed position, even some of my vintage 4 strokes. so do we REALLY need the pull back cable on the throttle? it just causes extra drag on the pull open. I suppose one could argue that its a "safety" feature....
    I equate it to wrapping yourself in bubble wrap just in case you fall.
    I probably would not take off a perfectly good one BUT the reason I bring it up is the pull back cable on my TW is shredded right at the carb cam and needs to come off and I am thinking why replace it? just something else to mess up. if you NEVER lube your cables you might have a stronger argument to keep it but I am on the anal side of lubing things so.....
    Dman
    grewen likes this.
    DMAN
    TW200D
    HODAKAS, 950 KTM ADV, YAMAHAS
    "EVERY SOLUTION IS THE SEED OF THE NEXT PROBLEM"
    YOU CAN HAVE IT GOOD, FAST, OR CHEAP = PICK 2
    IF ITS GOOD AND FAST, ITS NOT CHEAP. IF ITS GOOD AND CHEAP ITS NOT FAST, IF ITS FAST AND CHEAP , ITS NOT GOOD.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    like you said, it's a safety thing, i have wondered the same thing. 3 of my bikes don't have the return and i have never had an issue
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
  1. Throttle cable
    By bad luck in forum Technical Help
    Last Post: 08-07-2017, 06:51 PM
  2. Why is throttle Cable return TOO LONG ??...
    By JPMudHoney in forum Technical Help
    Last Post: 09-06-2016, 10:49 AM
  3. Single cable throttle assembly
    By mikeyrules in forum Technical Help
    Last Post: 09-28-2014, 05:55 PM
  4. positon of throttle cable pulley
    By Tyler in forum Technical Help
    Last Post: 05-16-2013, 09:49 PM
  5. Dual Cable Throttle?
    By Avi Kwame in forum Technical Help
    Last Post: 02-07-2013, 09:09 AM
