87 TW200 Won't crank at all or kick start.
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Like Tree11Likes
Thread: 87 TW200 Won't crank at all or kick start.
    Junior Member Brett's Avatar
    Oct 2017
    6
    I bought the bike for 350 because the kid started it (kickstart) right in front of me. Now it wont start by kicking or by the key. It needed new sprockets so after figuring out the crazy oil case that cover the front sprocket i got it all back together and had to kick the absolute shit out of it to start it, which it did eventually. When i bought the kid said the battery was dead and I didn't think much of it. But after opening it I realized it had no battery probably for a long time. Now it won't kickstart or crank over. the headlights turn on and what i believe to be the nuetral light ( the top cover is mia) comes on when the key is turn and i put it in nuetral. Im at a loss, I replaced the cdi but get no spark at the plug despite getting a new spark plug lead as well. Of note; the carb doesn't seem to fit into the airboot all the way? Its pressed against it but it doesnt slide in all the way like every other bike I've had.
    Any Ideas?
    Thanks in advance.
    Mar 2017
    Yuba City, CA
    403
    We might need to see some photos.
    When you put the side cover back on, there's a wire that's pretty easy to pinch, which would shut the whole thing down.
    Also, the headlight shouldn't come on with an '87, unless the engine is running... are you sure of the year? Has the engine been replaced with a later model?
    If it's running a newer engine (and newer wiring), then the CDI you installed is probably the wrong one.
    It sounds like the carb may have been replaced with something aftermarket. Mine came with a cheap Chinese eBay carb that was shorter than the factory carb... it ran pretty well, though.
    JerseyJeeper likes this.
    Mar 2017
    Yuba City, CA
    403
    Oh, and welcome to the forum!
    Mar 2011
    NJ Shore / Pine Barrens
    3,889
    +1 and CJ7Pilot hit all the points. Nice Job CJ! Jeepers always know what the H they're doing..
    Quote Originally Posted by CJ7Pilot View Post
    CJ7Pilot likes this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Mar 2015
    Ynys Môn
    4,629
    Welcome to the board
    We need pics of the bike in general (whole bike shot), and any other specific parts you regard as suspect - don't worry, we'll get to the bottom of this ....
    - Hidden Content
    19,016
    " it had no battery" ? Surely there would be no headlight nor neutral light illuminated without a battery to supply power. May we assume you have added a battery since the "it had no battery" comment?
    With battery power you say it "won't... crank over". Does this mean the starter motor is not engeaging nor turning over the engine, or that the starter motor turns over the engine but does not result in internal combustion?
    jtstdub likes this.
    Jun 2015
    Nova Scotia
    1,424
    If there's no battery maybe a capacitor?
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by Trail Woman View Post
    Thinking the same
    How strong is the spark?
    Sparkplug getting wet?
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    6,998
    Did you pinch the wires when you put the side of the case back on?
    When you kick it, close the throttle and hold it closed -- start with it closed and if that doesn't work then just a tiny teeny bit open. If you open the throttle it is very difficult to start.
    JerseyJeeper and admiral like this.
    Oct 2017
    6
    Alright I've just gotten back around to messing with this thing. I have replaced the battery, I currently have the headlight removed but the turn signals neutral light and whatnot turn on.
    I will check the title also when I get home but it may be an 89.
    I'll post pics tomorrow morning before work.
  1. Will crank, but won't start
    By Kevinophoto in forum Technical Help
    Last Post: 02-13-2018, 08:11 PM
  2. Replies: 3
    Last Post: 02-05-2018, 02:43 PM
  3. WANTED XT 225 Kick Crank Boss - Kick start levers etc
    By PlacerLode in forum TW200 Classifieds
    Last Post: 02-28-2016, 11:54 AM
  4. Kick Start Kick Crank
    By Frisbee in forum Technical Help
    Last Post: 07-11-2015, 12:41 AM
  5. kick start won't start
    Last Post: 01-15-2011, 06:23 AM
news
