Bike won't start in the mornings!
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    I've tried on 3 consecutive mornings to ride my bike. Temps were 42,54,58f. Bike sat out over night. Pull choke , turn on fuel wait 30 secs try to start. Each time ran battery down. Recharged while at work. Each time when I get home bike starts within 1-2 secs of hitting the starter button. What's wrong? Battery? Other? Thoughts?
    Junior Member BlueWRX's Avatar
    Oct 2012
    Madison, Wisconsin
    22
    I'd start by checking your battery terminals for tightness and corrosion, then check the Ignition systems ground points for the same. The coil is grounded beneath the fuel tank and the CDI is grounded in the battery area. If that doesn't help check your spark plug, see if it is getting spark and has proper gap.
    Sep 2012
    Alabama
    206
    Thanks I will check those. I also want to add that it would turn over for 30-45 seconds. At 5-8 secs at a time. Just don't understand why it starts easy in the evenings. I'll pull the battery and take it in for a check tomorrow as well.
    6,975
    Possibly moisture in the air condensing on the electrics shorting out something. It drys during the day and all is well.
    Try covering it with a cheap Harbor Freight tarp before putting it to bed and see what happens in the morning.
    Sep 2012
    Alabama
    206
    Good tip, would expain why it always started on cold mornings in the barn. If this is what is indeed hapening......any idea where this could happen? I would hate to get caught in a rain storm and have the bike shut down.
    Senior Member mrlmd's Avatar
    1,153
    Sounds to me more like you have a bad battery. You have no kickstart? Have you tried to roll start it or jump it with another battery?
    6,975
    Quote Originally Posted by kenfyoozed View Post
    My GUESS is around the spark plug and spark plug wire. Moisture condenses on the spark plug itself and the electricity goes down the outside of the plug.
    This may start an argument but you can spray WD40 on the end of the spark plug and up into the spark plug boot thing. That is suppose to keep moisture away. (WD40 is one of the items many people either love or hate and are passionate about it.)
    Let us all know what happens.
    Jun 2011
    Dothan, AL
    1,715
    Mine did that for a while it was a combination weak battery, corrosion in the battery cables and at the starter and I needed to turn the pilot screw out 3 turns. Now it will start without choke and it has been in the 40's in the morning. It is best to start these bikes in neutral, not in gear with the clutch pulled in. The starter doesn't spin the motor fast enough and the spark plug wont get enough juice. Switching to 10-40w in the winter really seems to help.
    2005 TW200 (SOLD)
    2013 DR650
    6,975
    Before trying WD40 take a dry paper towel, remove the spark plug wire and dry the spark plug and inside the boot with the towel. See if that does any good.
    Stanwood,Wa
    1,880
    This is what happened to me riding home in one of the worse rain storms I've ever been in, thunder,lightning pouring rain. Better than my shower. Bike just shut down on the HWY going 55, just coasted over to the side of the road and it would not start. Started to think of how I was going to get home. About 5-10 mins. later it just started up as if nothing happened. Rode the rest of the way home and have not had any problems since.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
  1. Replies: 50
    Last Post: 01-19-2015, 07:33 PM
  2. Bike won't start after I washed it down
    By fujimo in forum Technical Help
    Last Post: 04-30-2012, 05:25 PM
  3. bike locked up...where to start?
    By operose in forum Technical Help
    Last Post: 03-19-2012, 01:37 PM
  4. my bike wont start
    Last Post: 07-01-2011, 12:02 AM
  5. My bike won't start
    By jasonck08 in forum Technical Help
    Last Post: 11-15-2010, 01:57 PM
weak spark
why wont my bike start in the morning but will start in the evening
why wont my tw 200 start when cold
