89 tw200 won't turn ovee
Results 1 to 2 of 2
    Junior Member Zero_Blue's Avatar
    Apr 2018
    1
    My bikes been sitting all winter and I got a new battery for it. It powers up but won't turn over with kick or button. Do I need to drain the carb? If so where's the screw for it located and how long should I let drain? It's had fuel in it all winter
    Jan 2015
    Fair Oaks, Calif
    503
    Possibly your carb float stuck and it leaked into the cylinder and now it is hydraulic locked..... Remove your spark plug and see if the engine will turn over. Make sure that the plug wire is positioned as far away from the plug hole as possible. Don't want a fire...
    If there is gas in there then your crank case might have gas in it too... Quite common.
    Most of us turn the gas petcock off when the bike is not in use.
    Jim
  1. Engine won't turn wheel
    By Darryl in forum Technical Help
    Last Post: 07-13-2017, 11:35 PM
  2. Won't turn over!!
    By DOVERDUB in forum Technical Help
    Last Post: 11-19-2014, 07:28 PM
  3. 64 Miles on my TW and won't turn over
    By Scott K in forum Technical Help
    Last Post: 09-16-2013, 07:05 PM
  4. '09 won't turn over
    By TW200_CA in forum Technical Help
    Last Post: 10-30-2011, 10:19 PM
  5. 87 TW200 won't idle
    By heimy in forum Technical Help
    Last Post: 10-23-2010, 06:43 PM
