87 front brake
Results 1 to 4 of 4
Like Tree5Likes
  • 2 Post By TW-Brian
  • 3 Post By scotti158
Thread: 87 front brake
    Junior Member tjcgv's Avatar
    Apr 2018
    1
    87 front brake
    can an 87 be upgraded to disk brake, would i need a whole new front wheel ?
    Pleasanton, CA
    5,781
    Hi TJ,
    Welcome to the forum!
    Yes, a front drum brake bike can be converted to a front disc brake. You would need the following from a 2001 and up model year bike, minimum:
    -Front wheel hub with brake disc and front axle
    -Front brake caliper, brake line, brake lever/handlebar perch with master cylinder
    -Lower left fork leg
    The easiest way to perform this mod would be to find an entire front end from a 2001 and up model year bike.
    Brian
    Mar 2015
    Ynys Môn
    4,631
    Welcome to the board ...
    - Hidden Content
    May 2013
    Groton, NY
    2,663
    Brian
    They have these front ends stocked at most Yamaha dealers, about $4600, a bit pricey but they do throw in the rest of the bike for free. I have an earlier and a later TW, I don't notice a bunch of difference in stopping power between the 2 except on long down hills on the street, the disc is a more fade resistant. Off road I prefer the drum.
    Purple, TW-Brian and chainslap like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
  1. Big wheel front conversion with disc brake - 32H front hub options?
    By mr200sx in forum Performance and Customization
    Last Post: 04-28-2017, 10:41 PM
  2. Hi from Australia. Front brake and brake light
    By lozinoz in forum Technical Help
    Last Post: 04-05-2016, 06:21 PM
  3. front brake or rear brake for hill starts
    By mrx916123 in forum General Discussion
    Last Post: 03-27-2016, 07:29 AM
  4. New front brake?
    By tcepilot in forum Performance and Customization
    Last Post: 11-03-2014, 03:53 PM
  5. Front brake '99 - '01
    By dutchbat in forum Technical Help
    Last Post: 05-25-2013, 06:46 AM
