Who turns off the fuel petcock after each ride?
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Like Tree1Likes
Thread: Who turns off the fuel petcock after each ride?
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    So as the title says, whom of you make this a practice? Or what is your routine? Or do you even bother?
    Senior Member iowatdub's Avatar
    Aug 2012
    Iowa
    130
    Nope
    2008 TDUB
    Pleasanton, CA
    5,720
    My TW is the only bike that I routinely do this on. The petcock seems to leak a slight amount of gas - not enough to drip, but enough to stink up the garage. After riding, I shut off the petcock and allow the bike to idle until it dies.
    Desert, SoCal
    7,369
    I try to. The main reason for the practice is to prevent the possibility of filling the crankcase with gasoline due to a stuck float or a worn or debris-filled needle. That only needs to happen once for most people to become more conscientious about turning the petcock off.
    Most modern bikes come with vacuum actuated shutoffs which come with their own set of potential problems, but if that's all you've ever owned you may not be aware of the need to close the petcock manually.
    Senior Member Skyking's Avatar
    Nov 2011
    Frost, Texas
    572
    I've mostly had two stroke bikes, and if you've ever had one "load up"; you'll quickly learn to turn off your fuel.
    Jun 2011
    AZ
    793
    I do
    chevitz likes this.
    6,975
    If I park the bike in the garage I try to remember to shut it off. Otherwise I leave it on.
    Jun 2012
    Southern Michigan
    269
    I do. I try to remember to do it just before reaching for the key. The consequences of a leaky needle valve are worth it.
    Mar 2011
    Gobles, michigan
    1,824
    My wife and I both turn them off................. Over night only !!!!!! OMM.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Quote Originally Posted by kenfyoozed View Post
    After every ride I jack up the rear wheel, lube the chain, then turn off the petcock. Takes 3 or 4 minutes.
    Jb
  1. Petcock repair
    By Tirebiter in forum Technical Help
    Last Post: 04-15-2013, 07:23 PM
  2. idle mixture screw 4+ turns out?!?
    By a_frye in forum Technical Help
    Last Post: 11-28-2012, 04:35 PM
  3. Fuel petcock question
    By Boarder255 in forum Technical Help
    Last Post: 06-19-2011, 03:22 PM
  4. Gas Petcock
    By RockyTFS in forum Technical Help
    Last Post: 05-26-2011, 07:18 PM
  5. Pingel petcock
    By mtjoe in forum Technical Help
    Last Post: 03-13-2011, 07:00 PM
tw200 petcock to off after riding
