bent frame?
Results 1 to 8 of 8
Thread: bent frame?
    Member crossent's Avatar
    Oct 2010
    Newbury Park, Ca
    37
    I am looking for my first TW. My brother has found one down the street from him, but the owner says the frame is bent. He bought it that way intending on getting a new frame, but has decided to sell off some projects. He said someone that was interested in it said they bend in this paticular spot and they just weld a plate to reinforce. It is an 05 3k miles and wants 850. What is your opinions on the frame issue? It sounds like a good deal even with the frame issue. If you do a frame swap, what do you do with the vin?
    Thanks in advance,
    Mike
    90 tw 200
    New frame: I've had to take the receipt for a new frame, which shows the new VIN, and the old title and/or registration to the DMV and apply for a new title.
    Custom built frames: With frames I built from scratch I had to take the receipts for the steel and apply for a new title. Sometimes I'd stamp the existing VIN into the steering neck.
    Used frame: If I bought a clunker to reuse the frame I had to register the clunker and put all and put all my better parts on the clunker frame, so make sure the frame comes with a title.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Mike, given what my bike went through, it is hard to imagine that these frames bend easy. With my mishap, the fork tubes twisted in the triple tree causing the bike to pull slightly. It was an easy fix. Just a thought. Gerry
    Take care my Friend.........
    Oct 2010
    Newbury Park, Ca
    37
    I am tempted to buy w/o looking at it(since it is in another state). Seems like a good price(850) don't you think?
    Mike
    90 tw 200
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    i don't think it looks like that great of a deal. people find tw's around here all the time for around 1k.
    i would keep looking, spend a little more, and not have to deal with the frame/title issues. how much would a frame repair or a frame swap + title work and labor cost? i have seen frames on ebay, but shipping isn't cheap, and you'd be left with a motorcycle without matching numbers and the value would always take a hit because of that.
    now if you were buying that bike to do some crazy bobber/custom frame project, it would be a great deal, but if you want a tw the way a tw comes, i think you could save time, energy, and potentially money in just finding something with no or less severe damage.
    Junior Member sMoOsHy's Avatar
    Aug 2010
    Collierville TN
    10
    I paid 1800 for my 02 with 600 original miles. I wouldnt touch a bent frame bike like that unless it was free.. 2 cents
    Senior Member Petrus's Avatar
    Africa
    458
    A nifty little trick that you can do when buying any second hand bike is to drive through a wet patch on the tarmac (use a water hose to make a wet spot).
    Drive the bike trough/over the wet tar.
    You can then see if the bike has a bent/twisted frame by looking at the wet tracks on the tar.
    2008 TW200
    Senior Member davidsonsgccc's Avatar
    chickamauga, Ga.
    190
    total cost of a safe ridable bike is definetly something to consider when thinking of buying a damaged bike. without seeing it is hard to understand how bad the damage is but if the bike looks ridable besides the bend maybe you can straighten and rienforce exhisting frame. if this bike is significantly cheaper than what the average used one is going for in your area i wouldnt count it out. good luck making your decision.
    sorry about bad spelling my brain is having an off day.
    shawn
    not a TW owner but i play one on this forum.
  1. Bent Wheel
    By canadainshiver in forum Technical Help
    Last Post: 05-26-2013, 11:05 PM
  2. Sigh. Replacing bent front forks.
    Last Post: 03-10-2013, 04:53 PM
  3. Bent Forks?
    Last Post: 09-25-2012, 02:08 PM
  4. Bent Shfter Lever..
    By bookm in forum General Discussion
    Last Post: 06-15-2012, 02:00 PM
  5. Bent frame swap old to new
    By MxRacer69 in forum General Discussion
    Last Post: 03-13-2011, 11:01 AM
