Grease Gun and Grease Recommendations Please - Page 4
Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Like Tree95Likes
Thread: Grease Gun and Grease Recommendations Please
  1. #31
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,841
    Way too organized, way to much. Are those magnets from something up on top of the chart? I dismantled some computer hard drives recently and they had really strong magnets which somewhat resemble the shape of those on the chart. Just curious.
    That is really organized, I need to follow your example. If evolution were true, my garage will explode and out will come a new running partially wooden motorcycle.
  2. #32
    Senior Member jb882's Avatar
    Aug 2013
    1,374
    That is exactly what those are. Super strong, free( for me at least) and they come in handy.
  3. #33
    Aug 2013
    1,374
    btw.. is this too organized too?????
    I want to scrap those cabinets up top and build some new shelving with tool cubbies in it.
    admiral likes this.
  5. #34
    Member canyncarvr's Avatar
    Mar 2014
    State of Jefferson
    31
    This is off-topic...but a good place to maybe get an answer...........
    Are there metric and SAE zerks? Not the threaded portion, but the nipple portion.
    Some zerks fit right up with my grease gun, others 'leak' like crazy unless I hold the fitting on just right...and even then it takes a good bit of pressure on the fitting not not have it leak.
    The solution to having a metric zerk that leaks with my gun would be to replace the fitting on the gun? Or....hose on the gun in the case of a crimped on fitting. I would suppose that most wrenchers have both metric and SAE guns, then?
    Maybe a trip to an hydraulic-n-air place could crimp on a new fitting.
    It's always been a pain..but I've never looked into what it would take to resolve the problem. Most of my greasing stuff is suspension components that don't use a gun, but bulk grease.
    Thanks for any input.
  6. #35
    Aug 2013
    1,374
    I know there are metric threaded zerk fittings but i believe the nipple is the same. I have run into the similar issue as you but normally for me the little ball in the end of the zerk is not free and wont allow grease to pass. After i clean them off if grease wont flow easily i make sure the ball is free by poking it with an awl. if the ball is frozen or does not return to closed its time for a new fitting.
    Fred likes this.
  7. #36
    Mar 2014
    State of Jefferson
    31
    Quote Originally Posted by jb882 View Post
    That is an excellent refresher idea! I am familiar with that issue and have forced a reluctant zerk more than once. I'll also bet I've NOT tried that when 'oily leakage and failure to control it' has been a problem at hand.
    Thanks!
  8. #37
    Junior Member turp's Avatar
    Apr 2018
    6
    Quote Originally Posted by TopPredator View Post
    I like a grease gun you can pump with one hand, and with a universal nipple adapter so you can get into hard to reach places.
    A lot of nipples I find are covered in clothing.
    if you have trouble with yamaha grease fittings try alemite 308730 coupler it was only $8.50 at traction and it works.
  9. #38
    18,407
    If one has difficulties getting adequate axial alignment of the hydraulic coupler with the zerk fitting then a little plumber's teflon tape on the zerk threads can change it's position when bottomed out threaded into the swing arm. Or simply use a flex hose on the grease gun.
    SanDue and Ken like this.
  10. #39
    Member Denn's Avatar
    Dec 2018
    Arizona
    80
    There are a lot of good greases out there. I have 5 different greases I use on aircraft alone! You have to use what they specify.
    We put a new suspension on my buddy's F150 to mimic the Raptor suspension and it specified Super Lube synthetic grease.
    When I ran a dumptruck, I would by cases of Mobilegrease (red) 2 cases at a time. You can't imagine how many grease zerks are on a dumptruck. As far as using the red tacky grease from Lucas, I have found that it works well in sliding metal applications like the pivots on a backhoe but it is far from the best grease for axle bearings. Lucas makes an X-tra heavy duty grease that is better for roller bearings.
    I just use Aeroshell 22 on my swing arm because it is what was in my grease gun. Be careful with greases that have moly in them. They will ruin roller bearings.
  11. #40
    Member raffles's Avatar
    Jun 2012
    united kingdom (England)
    78
    Pmsl at that ha,ha,ha, nipples covered in clothing
  1. Lithium grease
    By Cascade Rider in forum General Discussion
    Last Post: 03-02-2018, 06:54 PM
  2. Grease Your Chain Fast
    By TopPredator in forum Technical Help
    Last Post: 05-10-2016, 10:47 AM
  3. Grease nipple size?
    By rtf in forum Technical Help
    Last Post: 06-12-2013, 06:55 PM
  4. Needle bearings and Moly grease
    By frog13 in forum Off-Topic
    Last Post: 06-11-2013, 05:53 PM
  5. Grease in Magneto (?)
    By msmiller in forum Technical Help
    Last Post: 09-07-2012, 08:13 PM
greasenipplesize
