2000 Carb on 89?
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By Purple
Thread: 2000 Carb on 89?
    Junior Member Mightyskip's Avatar
    Apr 2018
    1
    2000 Carb on 89?
    What is the difference in the carbs from older models to the newer? I have a 89 with 2000k miles on it. The person who had it before me ran dirty gas. I found a replacement for $45. I'd rather just take the old one off and rebuild it later as a swap spare. The one I found says 2000 and up. What's the difference?
    Mar 2015
    Ynys Môn
    4,637
    2000 and up used a CV carb — mostly to keep it under Japans stringent emissions tests
    Prior to 2000, it used the old style slide carb (reputed to be “slightly” better, though there’s little difference between the two)
    You can switch between the two styles as your want takes you, there’s no change in the engines — but as I understand it, there may be some alteration required in the inlet manifold rubber, and possibly the throttle cables (which may well end up being the wrong way round e.g. on the wrong side). This is just from memory, so don’t take my word for it ……
    However, all things are possible
    (Welcome to the board) …….
    JerseyJeeper likes this.
    - Hidden Content
  1. 1987-2000 Carb $130 shipped
    By flyhunter3825 in forum TW200 Classifieds
    Last Post: 05-16-2017, 03:18 PM
  2. 1987 to 2000 Shindy Carb Kit - OK
    By 1911garand in forum Performance and Customization
    Last Post: 01-31-2016, 10:22 PM
  3. WTD Carb for 2000 TW200
    By eldomike in forum TW200 Classifieds
    Last Post: 09-01-2015, 08:23 AM
  4. WTB Factory pilot jet for 2000 model carb
    By andy10889 in forum TW200 Classifieds
    Last Post: 07-16-2014, 09:04 AM
  5. 1987 - 2000 Model Carb Tuning
    By treybrad in forum Technical Help
    Last Post: 08-03-2010, 10:30 PM
