Elec Issue: All lights flashing with turn signals!
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree6Likes
Thread: Elec Issue: All lights flashing with turn signals!
    Member SCARE!'s Avatar
    Feb 2012
    New Zealand
    46
    So, I went down to the local testing station here in New Zealand to get my 6 monthly warrant of fitness..
    And low and behold, something has to play up..
    The guy calls me over, hey mate, your headlight and tail light are flashing too when the turn signals are activated..
    Just my luck.. never a problem til testing time..
    And it had to be an electrical problem, my un-speciality..
    Any idea what would cause this to happen? Maybe a ground needs looking at?
    I'm lost, and just want to ride!
    Any help would be greatly appreciated. I will give it a go, so you be the brain, I'll be the hands
    Senior Member Woofhound's Avatar
    Federal Way/Cle Elum Wa.
    369
    possible dirty battery connections? weak battery? clean terminals and turn up engine idle speed and see if that helps
    2009 WR250R
    2005 V-Strom
    1993 Shadow 1100 with Ural sidecar
    2008 H-D Ultra Classic
    2009 Zuma 125
    2004 Zuma 50
    2000 WR400F
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    I would try and evaluate if the lights are blinking on and off or if they are just dimming as power is drawn by the blinkers, if it is dimming I would take a look at the battery.
    -Szj
    2001 TW
    Germany, Werdau
    1,014
    I am really sure, that ground is the problem.
    I recommend to check all flasher light cables (the switch too).
    Peterb and Flyinspanner like this.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Quote Originally Posted by macbig2k1 View Post
    I second that.
    Feb 2012
    New Zealand
    46
    so... the head/taillights are dimming when the turn signal is flashing
    i have checked all the grounds i can see
    (my battery is only connected to the bike via the negative terminal, the positive has nothing connected to it - bear in mind the system has been modified in some way to use a small cell battery)
    i have tried turning up the idle, and although it helps, there is still flashing
    could it be the battery needs a trickle-charge up?
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Small cell battery is probably the culprit.
    Feb 2012
    New Zealand
    46
    So I bought a new battery, and boy! I don't think it's ever run on a battery before..
    I connected up the battery and the starter jumped into motion.. and wouldn't stop trying to start.
    I tried disconnecting the starter button (that is loose) on the RH switch block, no change..
    So where to now? It has obviously never had a fully charged battery the whole time I've had it..
    and the brake/headlight is still flashing/dimming when the turn signal is on..
    Anyone??
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Quote Originally Posted by SCARE! View Post
    ... bear in mind the system has been modified in some way to use a small cell battery)
    If this is so, there may other wiring that has been changed.
    It's likely that you will need someone with motorcycle wiring knowledge to check all you wiring circuits with a meter.
    My first thought was a miswired flasher relay, but with unknown wiring changes, it could be anything.
    jb
    Feb 2012
    New Zealand
    46
    Quote Originally Posted by jbfla View Post
    jb
    Agree to all of the above.
    What is making me want to fix it myself, is that it was all good one day, then the bike sat for 2 months, and it has this gremlin. I can't see what could have made it not work. Surely something simple..
    Thanks!
  1. Lights / turn signals not working
    Last Post: 01-04-2013, 07:20 PM
  2. Electrical Issue - Flickering LIghts
    By TeeDubs in forum Technical Help
    Last Post: 01-15-2012, 01:14 PM
  3. turn signals
    By tw200_87 in forum Technical Help
    Last Post: 08-09-2011, 05:57 AM
  4. Rear signal lights: turn signals only?
    By thal13 in forum Technical Help
    Last Post: 04-24-2011, 06:57 PM
  5. turn signal, right rear, "quick" flashing, good bulb
    By flybill59 in forum Technical Help
    Last Post: 09-12-2010, 09:46 PM
changing flasher relay for tail lights on 2012 yamaha zuma 125
my 08 softail deluxe my lights are blinking
triumph bonneville electrical problems turn signals
