Front brake cable/lever?
Results 1 to 3 of 3
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    I know this sounds crazy but is there a trick to removing the front brake cable? I cant seem to figure out how the cable disconnects from the font hub. The cable runs trhough a round"block" that is trapped in the brake cam lever. You cant push the block out because the cable keeps it from coming completely out of one side........Help please...
    Desert, SoCal
    7,369
    Do it from the handlebar end.
    Back the thumb nut off of the adjuster (Away from the lever).
    Screw the adjuster all the way in (toward the lever). Line the groove in the adjuster up with the slot in the perch and the thumb nut and slip the cable end out of the lever.
    That will give you enough slack to get it loose on the brake drum end. Loosen the jam nuts on the cable at the brake drum and that will give you the rest.
    You'll sometimes need to actuate the brake arm by hand and do a little fidgeting to get the cable end out of the brake arm. If you've got a fresh cable you may even need to remove the brake arm and rotate it to get it out, but it will come out.
    If it turns out that you need to remove the arm be very careful not to use too much force when putting it back on the splines. If you do you'll push the pin out og alignment with the shoes and you'll have to remove the front wheel to fix it.
    Tennessee
    1,288
    +1
    The only way you could do it starting at the drum would be to have a really loose cable already or the ability to crush the shoes by actuating the arm with your hand.
  1. Replies: 2
    Last Post: 05-28-2013, 11:00 AM
  2. Longer Front Brake Lever
    By ronnydog in forum Performance and Customization
    Last Post: 12-31-2012, 02:48 PM
  3. Front brake cable/lever?
    Last Post: 11-09-2012, 01:48 PM
  4. Hard front brake lever
    Last Post: 02-25-2012, 10:32 AM
  5. front brake lever
    By RisingSun in forum Technical Help
    Last Post: 10-11-2011, 01:18 PM
tw200 drum brake adjuster
tw200 yamahafront brake cable
yamaha tw200 brake levers
