Is the pilot jet blocked lengthwise?
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree3Likes
Thread: Is the pilot jet blocked lengthwise?
    Senior Member biglefti's Avatar
    Oct 2010
    SCW, AZ
    527
    My bike has been idling poorly for awhile. I crashed it pretty hard this spring and haven't ridden it since and just figured the pilot circut shellacked up a bit. Well, I pulled the bowl and everything is really clean with no dirt or grime anywhere. I pulled the pilot jet, and was looking on the Easy TK cleaning post and it said that I should see light through the end as well as the side drillings. The side drilling are very clean, but I could not see through the end. I took a small drill and just using my fingers to turn it tried to clear the passage through the bore from the end. No go from either end. It appears to be blocked by brass as though it was made that way. Do any of you have you TK apart and can look? Or are any of you positive. I don't want to drill it through and then find that was the wrong thing to do. TIA. BTW, my TW is a 2003
    Desert, SoCal
    7,369
    Step away from the drill bit.....
    Soak it, blow it out, probe it with one strand of soft copper wire but no NOT put anything resembling a hardened drill bit through it. If you increase the size of the hole in the process of cleaning it the bike won't run right when you're done.
    Oct 2010
    SCW, AZ
    527
    Thanks for all of that, but what I need to know is if it is actually bored lengthwise. if so is it a reduced orifice for just that little distance. It is a fairly cheap part from Ron Ayers, but then it might not run until then. Of course it doesn't run good enough to ride right now. If it is just a reduced orifice for that small distance, does anyone know the dimention. I have a numbered drill set and the number on the bottom of the jet is 31, but I don't know if that means .031" of if it is just a Yamaha or TK ID number.
    Desert, SoCal
    7,369
    You're correct. The actual orifice is in the end of the jet and is stepped down from the i.d. of the portion with the bleed holes.
    It's a #40 jet, but it's a Teikei #40 and not neccessarily a #40 drill size.
    Be patient and be careful with it. I prefer to use a Guitar "E" string or remove one strand of copper from a length of #14 stranded wire to loosen the crud after soaking. Personally I never try to clear a dry or hardened deposit without pre-soaking. Tends to cock things like drill bits sideways into the brass.
    Oct 2010
    SCW, AZ
    527
    Ok, thanks, I will try soaking it first, but whatever is in there looks like a piece of brass stuck in sideways. I haven't been able to push anything through from either side so far. In the mean time, I think I will just get a new one on the way.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    That center/end hole is where the fuel/air mixture is fed into the pilot passageway. Air comes through the side holes, and fuel comes through the bottom hole.
    The stock pilot jet in your 2003 is a #31. The end hole is so small that the thinnest carb cleaning wire will not pass through.
    Jb
    scootah likes this.
    Senior Member Skyking's Avatar
    Nov 2011
    Frost, Texas
    572
    What are you using that #34 on?
    Oct 2010
    SCW, AZ
    527
    Quote Originally Posted by jbfla View Post
    Jb
    That's perfect, thanks!
    Desert, SoCal
    7,369
    Jb
    Good call on that. Early slide carbs had the 40's. My bad.
    FL. GA, NC
    2,396
    Quote Originally Posted by Kwizard View Post
    I have it in my 2005 TW. It's from an XT250.
    I have no explanation, but my bike starts and runs better with the #34. It does run rich, according to the plug color, but does run better, IMO.
    I'm not making a recommendation to others. It works for me.
    Jb
  1. pilot jet
    By greendub in forum Technical Help
    Last Post: 08-27-2013, 07:16 PM
  2. Pilot screw set
    By dantilghman1 in forum Technical Help
    Last Post: 01-25-2013, 11:05 AM
  3. Pilot Jet
    By Joe in forum Technical Help
    Last Post: 01-11-2012, 07:34 PM
  4. Mi IP is blocked
    By rm_hm in forum Test Forum
    Last Post: 05-17-2011, 10:27 PM
  5. Pilot Jet adjustment
    By bruisr in forum Technical Help
    Last Post: 09-12-2010, 07:21 PM
can you see through a pilot jet
cock thread brake beeg
how big is a 31 pilot jet
mikuni pilot jet hole locked clogged
pilot jet hole
pilot jet hole size
something is blocking pilot jet hole
tk 22 drilling pilot jet
tw200 carb pilot jet hole all the way through
tw200 larger pilot jet
tw200 pilot jet
yamaha tw200 carburetor problems
