ttr225 motor in a tw?
Results 1 to 10 of 14
    Junior Member stan's Avatar
    Aug 2012
    8
    I have a ttr225 and was wondering if anyone had ever swapped one into a tw. 30ccs and a sixth gear would be nice. Thanks stan
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    Quote Originally Posted by stan y View Post
    I don't know about bolting in the TTR engine, but Ronny was able to up the displacement of the TW engine to a 250 and also added a 6th gear.
    This thread should interest you.
    https://tw200forum.com/index.php?/top...__hl__ronnydog
    -Szj
    2001 TW
    Aug 2012
    8
    Wow! I've got everything but the money to do that....lol....stan
    Member trailway's Avatar
    Nov 2012
    South Carolina
    65
    That would make an almost perfect bike better.
    Senior Member rm_hm's Avatar
    1,619
    Qwerty thought
    "I'm thinking a combination of TTR230 and TW parts. According to the Japanese Tdubbers, the TW countershaft can be ground to accept the TTR 6-speed and clutch as otherwise bolt-in mods. I've looked at the TTR ratios and they look very good. xr100.com used to do a 250cc bore TTR engine that dynoed 28hp. Use the xr100.com head, cylinder, cam, carb, and exhaust with one of Sebastian's stroker cranks and assorted goodies like a 520 chain conversion, and you'd have the ultimate TW in the stock cases so the numbers match when you get stopped for being a holigan."
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    I know somebody with a ttr crank in a tw motor...something like 230cc's
    Desert, SoCal
    7,369
    I'm building a TTR motor for my TW as we speak. Perfectly doable, but you'll need to split the cases on both motors and install the TW trans and output shaft. This will basically render your old TW motor a transmission-less doorstop, but no way around it. You gotta have a TW output shaft and 5-speed, or have a machinist in your pocket who can modify your TW output shaft for the six speed.
    Transfer the TW flywheel, left side cover and electricals to the TTR motor. You can keep the bigger TTR clutch and right side cover, but if you want a kickstarter you'll need the TW kicker parts and an XT225 right side cover.
    Your existing TW carb and maifold will bolt right onto the TTR. All the heads are essentially the same. Same valves, same exhaust and intake flanges.
    The TTR Mikuni won't fit into a TW frame without some frame grinding. It will be a tight fit but you wanted to use it I'd mount it to your stock TW motor while it's still in the frame and make careful notes about what areas need clearancing. Do the grinding once the motor is out. The you'll have to figure out a way to adapt the airbox boot to accept the much larger Mikuni inlet mouth.
    Poway CA.
    2,100
    I'm building a TTR motor for my TW as we speak. Perfectly doable, but you'll need to split the cases on both motors and install the TW trans and output shaft. This will basically render your old TW motor a transmission-less doorstop, but no way around it. You gotta have a TW output shaft and 5-speed, or have a machinist in your pocket who can modify your output shaft for the six speed.
    PIC'S ??????
    Ronnydog
    Desert, SoCal
    7,369
    Troublemaker. I don't want the guy with the pink motor to see how I got the extra 2 cc's.
    Make yourself useful. Kenfyoozed could use some advice:
    https://tw200forum.com/index.php?/top...ngine-builder/
    Poway CA.
    2,100
    I just finished a TW 230. 71mmx58mm
    Ronnydog
  1. XT-200 - same motor?
    By dpawl31 in forum General Discussion
    Last Post: 06-20-2013, 05:30 PM
  2. Installing TTR225 clutch
    By yz250f4ever in forum Technical Help
    Last Post: 01-24-2013, 09:10 AM
  3. ttr225 header
    By kripton in forum Technical Help
    Last Post: 06-04-2011, 04:43 PM
  4. TTR225 engine in a TW200, extended front sprocket shaft?
    By Skullhag in forum Performance and Customization
    Last Post: 05-01-2011, 06:27 PM
  5. ttr225 piston in a tw200 cylinder
    By racerx in forum Performance and Customization
    Last Post: 08-18-2010, 03:22 PM
is the xt 225 cam the same grind as the ttr225
ttr225 gear ratios
ttr225 motor on a tw200
tw200 ronnydog 225
tw200 swingarm on a ttr 225
tw200 xt225 motor mount interchangeable
will a tw200 transmission fit in to a ttr225
xt200 countershaft
xt200 countershaft tw200
xt225 cam grind
xt225 engine in tw200 frame
xt225 engine mount
