Nothing happens when I turn key
Results 1 to 8 of 8
    Junior Member chefallen's Avatar
    Dec 2012
    1
    Someone stole my bike and dumped it in a lake. cleaned evrything motor wise and tried best to to check all electric. turn signal and headlights etc all work fine. Nothing happens when I turn key, no instrument panel lights and no power to turn starter. Any help would be greatly appreciated. 2006
    Senior Member mrlmd's Avatar
    1,153
    Did you check your battery voltage to see if it's dead? Check fuses?
    Desert, SoCal
    7,369
    Quote Originally Posted by mrlmd View Post
    Zackly. If the bike was submerged for any length of time the battery acid has likely become pure water by dilution.
    That's probably the least of your problems. Obviously you'll need to drain and refill the crankcase, airbox, fuel tank, float bowl, get the emulsified oil out of your air filter, etc. Pour a few tablespoons of oil through the spark plug hole and spin the plugless motor before trying to start it for real. Yada, Yada.
    Tennessee
    1,288
    If they stole it via hotwiring it, that's also part of why nothing happens. But very likely your battery tanked if it's not the sealed type.
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    was the steering locked? did they break that to steal it?
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    its not in gear is it? that may keep the lights from coming on?
    Member trailway's Avatar
    Nov 2012
    South Carolina
    65
    There is also a fuse link on your positive lead coming from your battery that could be blown. When i bought
    mine the guy said the starter doesn't work and he didn't know why. He said it may just need a new battery.
    When i got it home i could tell the battery was brand new so i checked the fuse and that was my problem. Luckily
    it had a spare in the fuse holder.
    Tennessee
    1,288
    Quote Originally Posted by trailway View Post
    Good thinking. We all overlooked that, but that's one of the first things most of us probably do when we don't get power.
  1. Turn signals
    By yz250f4ever in forum Performance and Customization
    Last Post: 03-16-2015, 03:15 PM
  2. wont turn over
    By hootie66 in forum Technical Help
    Last Post: 02-28-2013, 01:36 PM
  3. TW wont turn over
    By TeeDub in forum Technical Help
    Last Post: 09-05-2012, 09:16 PM
  4. '09 won't turn over
    By TW200_CA in forum Technical Help
    Last Post: 10-30-2011, 09:19 PM
  5. turn signals
    By tw200_87 in forum Technical Help
    Last Post: 08-09-2011, 05:57 AM
tw200 turn key nothing happens
