Finding the Compression Ratio
Results 1 to 7 of 7
    Poway CA.
    2,100
    This is beyond me on how to come up with the compression ratio.
    What I do know is the motor is 71mm piston x 62mm stroke and the top dead center head volume is 26cc. I could use some help.
    Thanks, Ronnydog
    Desert, SoCal
    7,369
    In raw numbers it's 10.4:1 with a flat top piston and 26cc head.
    Not accounting for head gaskets or domed pistons though.
    Poway CA.
    2,100
    Head gasket .90mm and the piston is domed, stock piston 9.5 to 1, domed piston 10.25 to 1.
    Ronnydog
    Desert, SoCal
    7,369
    The gasket adds 3.56 cc's to the chamber volume, which brings it down to 9.3:1 with flat tops.
    With gasket the Wiseco dome would need to take up at least 3cc's to bring you back to 10.25:1. I'm pretty sure it will, but I don't have a decent way to measure it.
    Assuming it's 1mm tall it takes up 4mm, minus the edges.
    In any case you should be well over 10. Maybe Sebastian has calculated the dome.
    Those Nikasil XT's are killing any chance of anyone bothering to make us anything bigger. Not that I want you to get your hands on anything bigger , but I'd be pretty tickled with a 72mm at 9.5:1.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    the hardest part of compression calcuation is the TDC volume. The surest way of finding that is with the head off. Close the valves and see how many ccs of liquid it takes to fill it. Same with the piston head @TDC.
    Once you have that the rest is simple math.
    Stephen S.
    '07 TW200:
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    Probably bigger than mine
    Desert, SoCal
    7,369
    Quote Originally Posted by srs713 View Post
    Everything is known but the volume of the dome. In a motor this small being off by a cc can mean half a point in compression ratio. Even simple math gots to be right.
  1. What should engine compression be at?
    By Beewerks in forum Technical Help
    Last Post: 07-15-2017, 10:40 AM
  2. Compression check
    Last Post: 04-29-2013, 06:13 PM
  3. Engine loses compression when warm
    By Uwdlk2no2 in forum Technical Help
    Last Post: 04-22-2013, 07:20 PM
  4. help finding picture
    By phazer in forum General Discussion
    Last Post: 08-03-2011, 07:34 PM
  5. Compression Test
    By Henrici in forum Technical Help
    Last Post: 09-27-2010, 02:58 PM
