Turn Signal Wiring
Results 1 to 10 of 13
    Junior Member Jtrez's Avatar
    Dec 2012
    Gainesville, FL
    15
    Hi. I am new here. Just got a '93 TW in Gainesville, FL yesterday. It runs great, but I'm having problems with getting it road ready. It had some aftermarket turn signals on the back and none on the front when I got it. The back turn signals were mixed up L/R and stayed solid. I got a couple questions about how to wire up some front ones, since I can't seem to find where to plug them up.
    Lets start with this: What color wires should I be looking for to plug the new front turn signals into? Since I don't see any obvious plugs I am assuming someone did some splicing, maybe bypassed the flasher relay.
    Also, If anyone could point me to a wiring diagram for my year bike I would appreciate. I have seen the new one, but not sure if that is the same.
    Thanks.
    1993 TW200
    Senior Member Skyking's Avatar
    Nov 2011
    Frost, Texas
    572
    There is a service manual and supplement in the tech section. It's kind of a long download; but worth the trouble. You'll need it for other stuff as you go along.
    Sep 2011
    Southcoast MAsshole
    2,661
    Dec 2012
    Gainesville, FL
    15
    Thanks guys. Found the manual, gonna try to fix it after work.
    1993 TW200
    Dec 2012
    Gainesville, FL
    15
    I have been studying the manual and trying to figure out where to plug in the new front turn signals but am still having trouble.
    I looked at the wiring harnesses and noticed some open plugs but am not sure if thats where they go.
    I'd appreciate if anybody with experience could look at this pic and tell me if this is the place to plug in my front signals. I got 1 open green, 1 open brown, one open double black, and one open double blue...
    1993 TW200
    Ephrata, WA
    1,125
    You are right on.
    Double blue
    Double black
    Single green
    Single brown
    Don't know if brown is right or left or if green is left or right. Plug them in and switch if wrong.
    1990 TW200
    Dec 2012
    Gainesville, FL
    15
    Thanks for all your help.
    Sorry to say I am still having trouble getting the signals to work. I bought these front and rear aftermarket ones off motorcycle superstore. They stay lit solidly once plugged up and each rear signal appears to get a little brighter when I throw the handlebar switch.
    I tried swapping my flasher relay for a generic 12v thermal one from the auto parts store, but it made no difference. There is power on the brown wire going to the flasher relay and once plugged up power to the brown and white wire also. Anyone have any idea why they aren't blinking?
    1993 TW200
    Nov 2011
    Frost, Texas
    572
    Hit all those connections with some WD40. Check to be sure the rears are wired in correctly. Try the black on the blue, and the blue on the black. The wiring diagram gives the colors in two letter codes; ie; black is probably bk, blue is bl or something close. Check your grounds, and power lines. Look for areas where the wires may be pinched together or to the frame.
    Nov 2011
    Frost, Texas
    572
    Hit all those connections with some WD40. Check to be sure the rears are wired in correctly. Try the black on the blue, and the blue on the black. The wiring diagram gives the colors in two letter codes; ie; black is probably bk, blue is bl or something close. Check your grounds, and power lines. Look for areas where the wires may be pinched together or to the frame. I hate electrical stuff on motorcycles. Some times you gotta sit there for and hour and stare at it, and follow each wire beginning to end. You know; just thinking it all through.
    Jun 2011
    Dothan, AL
    1,715
    The fronts should stay on all the time. They flash with the switch. The rear lights should be off normally and only flash with the switch.
    2005 TW200 (SOLD)
    2013 DR650
  1. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
  2. LED turn signal heads up
    By operose in forum Technical Help
    Last Post: 03-24-2012, 09:33 AM
  3. WTB: OEM Turn Signal Indicators
    By joet3ch in forum TW200 Classifieds
    Last Post: 11-09-2011, 01:43 PM
  4. WTB - Turn signal lens.
    Last Post: 11-04-2011, 08:30 AM
  5. Wiring front turn signals
    By SigepKat in forum Technical Help
    Last Post: 07-18-2011, 02:27 PM
1990 tw200 blinker relay
how to wire tw200 rear turn signals to always be on
keeway superlight 200 turn signal wiring
turn signal
tw200 turn signal wiring
tw200 turn signal wiring diagram
tw200 turn signals wiring
wiring diagram 1993 yamaha tw200
wiring diagram for blinkers 1993 yamaha xt350
wiring up lights on my 87 tw200
yamaha 3 wire turn signal
yamaha tw 200 signal wont work
