1987 roller.....
Results 1 to 4 of 4
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    I got an '87 as a parts bike with another bike i bought. I would like to get the 87 running just to use on trails. No lights of any kind are needed. I know the '87 is an unusual model in the electrical field. I havent really checked to see how much of the wiring is still left. Is it possible to use a wiring harness form another year and make it work with the '87, just to make it run? The electric start isnt needed either.
    It really is a bare bike, no plastic, tank, seat, carb etc.... clutch and gear shifter seemed to work, spark plug broke off but at the metal hex part, but the plug should be able to some out. Ill post pic later today.
    Sep 2012
    Alabama
    206
    Didnt get pics, sorry. I did try to turn the engine over by removing the sparkplug, and leaving the bike in gear and attempting to roll it. Nothing happened. I assume the engine is locked up, so this might just be a dead horse im beating.
    Member cbamarun's Avatar
    Aug 2011
    Atlanta,Ga
    91
    There is a 87 on south ga. craigslist that is taken apart and for sale.
    Desert, SoCal
    7,369
    Most likely a case of kickstanditis. Bikes that have been sitting for long periods can rust the rings to the cylinder walls. It's usually not a good idea to run a motor like that without removing the head and cylinder to check the bore, but they can often be freed up enough to get them apart and save them.
    Remove the plug. Pour about 1/4 cup of Marvel Mystery oil down the spark plug hole and go away for at least a day.
    Remove the valve covers and squirt some oil far enough back to hit the cam lobes.
    Then pull the crankshaft nut cover. Bump it slightly BY HAND if it will move, then let it sit. If it moves don't be tempted to kick it through just yet. Let it sit for awhile, move the crank a few degrees, repeat.
    Be patient and resist the temptation to use the kicker or electric starter and you may get lucky and have a motor that will only need new rings and a light honing to be good as new. Force it and you'll have a useless brick.
  1. i need a cdi for a 1987
    By infamous145 in forum TW200 Classifieds
    Last Post: 05-16-2012, 12:30 PM
  2. 1987 CDI
    By Hotrodjohn in forum Technical Help
    Last Post: 02-21-2012, 12:09 PM
  3. 1987 tw200
    By big jim in forum General Discussion
    Last Post: 12-03-2011, 04:35 PM
  4. My 1987 TW
    By BBMS in forum General Discussion
    Last Post: 09-22-2011, 09:37 AM
  5. Looking at a 1987 TW
    By Pilsner in forum General Discussion
    Last Post: 09-08-2011, 01:37 PM
