Right Signals Non Functional--any advice?
Results 1 to 2 of 2
    Junior Member JHS's Avatar
    Aug 2010
    10
    Hi Everyone,
    I have a 2005 TW200 equipped with LED front signals, and a Yamaha LED rear with integrated signals.
    Recently, the right signals (both the front led signal and the integrated right rear flasher) stopped working, though the left signals work fine.
    As the signals on both front and rear went out at once, I'm not inclined to believe that it's just a matter of a burned out LED.
    Has anyone experienced a similar problem, or have any suggestions on diagnosing the matter?
    Thanks in advance.
    Ahhhh, the joys oftroubleshooting custom parts. Since both went out at the same time I'd start with checking for a corroded/loose/disconnected wire and follow that up with checking the function of the turn signal switch.
  1. Rear Turn Signals
    By philp38 in forum Technical Help
    Last Post: 06-20-2019, 11:29 AM
  2. Turn signals
    By yz250f4ever in forum Performance and Customization
    Last Post: 03-16-2015, 03:15 PM
  3. LED Signals In Front, Now For The Rear?
    By tgmnation in forum Technical Help
    Last Post: 06-08-2014, 05:05 PM
  4. turn signals
    By tw200_87 in forum Technical Help
    Last Post: 08-09-2011, 05:57 AM
  5. Wiring front turn signals
    By SigepKat in forum Technical Help
    Last Post: 07-18-2011, 02:27 PM
