Swapping rims?
Results 1 to 6 of 6
Thread: Swapping rims?
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    my '09 is set up with street tires. I thought about getting another set of rims with dirt knobbies. The idea is to swap the two when ever i ride more dirt. Like next week i want to go ride some logging roads. I know my street tires should be ok, but the few times ive had them off road i didnt lke how they performed. So is swapping back and forth a bd idea, especially on the chain and sprockets?
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    In my opinion it's a great idea. The cost is steep for a set of TW wheels, especially since yours is a disc brake front wheel.. But cheaper than two TW's!
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Sep 2012
    Alabama
    206
    I have a set of 87 wheels, but i need a disc front wheel. Ill start to keep my eyes open....
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Sounds like a good idea to me....if YOU, can tolerate the switching back and forth?.
    Senior Member howardgene63's Avatar
    Mar 2012
    central missouri
    234
    I think a spare rear wheel with one of the agressive atv tires on it would be sweet, then run something like a shinko 244 all the time in the front and just switch
    out the rear, but everyones different.
    Tennessee
    1,288
    I would say buy a separate sprocket as well, or look into the dual sprocket mod that's been done. This way, you can have street and dirt gearing as well. If you do this, remember to keep some master links, spare chain, and the chain tool around.
    Changing wheels with discs is a little harder to do with speed I would think, but I've never been in a rush to do it. Just make sure brakes are working well before you haul off.
  1. Aluminum & steel rims, stainless spokes?
    By retro in forum General Discussion
    Last Post: 06-26-2017, 10:56 PM
  2. WTB two motorcycle rims and tires
    By oceanickid in forum TW200 Classifieds
    Last Post: 04-18-2012, 05:15 PM
  3. Swapping plastics and tanks
    By chevy_lifted_4x4 in forum Performance and Customization
    Last Post: 02-09-2012, 05:56 AM
  4. Swapping out a fork boot
    By cdsdave in forum Technical Help
    Last Post: 08-07-2011, 09:07 PM
