correct front boot size for 87 tw
Results 1 to 5 of 5
    Member hertha's Avatar
    Dec 2012
    43
    Hi,
    I've had my tw for about a year and have been cleaning it up. Am working on front forks and want to swap out the yellow boots for black. any idea where i can buy replacements?
    thx hertha
    Desert, SoCal
    7,369
    The fork tubes are 33mm if you're shopping aftermarket.
    I use Daystars.
    Ephrata, WA
    1,125
    Daystars fit, but they are not a perfect fit. I like mine. They were WAY cheaper than stock, they look good, and they do the job. With a little "fine tuning" they do just fine.
    Check out what I did to make them fit a little better.
    I have since removed the stock upper clamp and replaced it with a generic hose clamp. I also used a black zip tie on the bottom to snug the boots up a little bit. They haven't moved since I did it this spring. The boots look great and work just as good as the stock ones.
    1990 TW200
    Dec 2012
    43
    I use Daystars.
    Hey Raiman, appreciate it, will have a look , hertha
    Dec 2012
    43
    Quote Originally Posted by hertha View Post
    Hey Raiman and lzdbrth, appreciate it, will have a look , hertha
  1. Fork boot size?
    By trailway in forum Technical Help
    Last Post: 11-21-2012, 09:20 PM
  2. Front tube size
    By JerryW in forum Technical Help
    Last Post: 02-07-2012, 03:06 PM
  3. Front Shock Rubber Boot Question
    By Homeskool in forum General Discussion
    Last Post: 03-10-2011, 04:33 PM
  4. Front Fork tube size diameter/seal&dust boot kit
    By bruisr in forum Performance and Customization
    Last Post: 02-19-2011, 06:07 AM
  5. Front Tube Size??
    By Quicksand in forum Technical Help
    Last Post: 11-25-2010, 12:44 PM
