Lights / turn signals not working
Results 1 to 10 of 13
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    this is a 1996 model. Replaced all the bulbs, and now the neutral indicator and hand brake light works. Ill assume for the momment the foot brake switch has gone out. The turn indicator light stays lighted. None of the turn signals work. and head light has but one beam. not sure if its hi or low. in looking at the wiring i am seeing a blue wire from both front turn signals that is not connected. I assume these should be , but dont see anything to connect them to. Both are male bullet connectots. In looking i also see a wire nit and some splicig so ill look again and get more details. Im rushed for time now but thought someone may have a few words to guide me..... thanks
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Im a little rusty but if I remember correctly the front turn signals are meant to stay on with the stock signal/bulbs. They are the running lights and they have two filaments in them. If you are using aftermarket turn signals you will leave one of the wires off because they usually lack the running light feature and have only one filament. Also, the stock flasher relays tend to go bad but a generic flasher relay is about $5 at autozone and plugs right in.
    As for the headlight I think you just replace the bulb (35w), sounds like one of the filaments in it has broken.
    Tenaciously Deviant Unwittingly Brilliant
    Desert, SoCal
    7,369
    On a '96 your front turn signals also seve as running lights. They should be lit any time the key is on. The rears remain unlit unless the signals are on.
    Sep 2012
    Alabama
    206
    I'll double check the flasher relay. The front turn signal lights do not come on at all. I will find a wiring diagram and see what those blueeeeee wires went to.
    Sep 2011
    Southcoast MAsshole
    2,661
    Fort Payne is right...the front blinkers have 3 wires to each of them (the 3rd is for the running lights)...the rears only have 2...if you need more info check out the wiring diagrams in the manuals
    https://tw200forum.com/index.php?/top...epair-manuals/
    Sep 2012
    Alabama
    206
    Thanks guys...
    I took a look at the wiring diagram last night and i saw that the blue wires should connect to blue wires..... 2 into 1. I didnt see the missing female lead. I meant to snag the flasher this morning but forgot. So i guess that will have to wait until tomorrow. Ill check the sticky as well... i thought i had seen that somewhere.
    And another question.... Is the headlight bulb motorcycle specific? or should a buld off the shelf at the auto parts store work?
    Sep 2012
    Alabama
    206
    Switched out the turn signal relay and the signals started working. So Thanks for the heads up on that relay, it totally slipped my mind. The running light portion of the front signals still dont work. I looked for a place to plug in those 2 blue male ends, but found nothing empty. What i did find was a blue female that was conncected to a blue male going to the speedo light. I unplugged it and tried each signal and the running light would start working on the respective side. So ill get a few female bullet ends amd make a pigtail and tap them all into that one. Bike was made 7/95 buts its titled as a 96. Dont know if that helps.
    Junior Member Jtrez's Avatar
    Dec 2012
    Gainesville, FL
    15
    I had kind of a similar problem not knowing where to plug the turn signals in a few weeks ago. The guys on this forum helped me get it worked out. The plugs I found were way down in one of the wiring harnesses on the front brake side. You might want to give this thread a look before you go splicing things.
    1993 TW200
    Sep 2012
    Alabama
    206
    l pulled the head light off to get a good look of things. I cut a very cable ties which allowed me to pull the bundled mess out of the black plastic/rubber protective cover. There is no place to plug these into. It seems strange. But the PO must have thought the same, because the 2 blue male wire ends were wrapped in red electrical tape. Not sure where the female end went?
    Nov 2011
    Alabama
    326
    The extra wire comes from the bike right? With no place to plug into the turn signals?
  1. Rear Turn Signals
    By philp38 in forum Technical Help
    Last Post: 06-20-2019, 11:29 AM
  2. Elec Issue: All lights flashing with turn signals!
    By SCARE! in forum Technical Help
    Last Post: 04-06-2018, 12:38 AM
  3. Turn signals
    By yz250f4ever in forum Performance and Customization
    Last Post: 03-16-2015, 03:15 PM
  4. turn signals
    By tw200_87 in forum Technical Help
    Last Post: 08-09-2011, 05:57 AM
  5. Rear signal lights: turn signals only?
    By thal13 in forum Technical Help
    Last Post: 04-24-2011, 06:57 PM
lights do not work on tw200
switched signal lights from 2 wire to 3 wire signals not working
tw 200 signal not flashing
wiring new turn signals on tw200
yamaha tw 200 lights not turning on
