87 starting problems
Results 1 to 3 of 3
    Member mkriley's Avatar
    Jun 2011
    71
    have a 87 that I,ve put 3k on and has always been a hard starter. Almost impossible to kick start unless warm.
    have set the idle air jet at 3 turns out and it starts ok on the electric start with minimal choke in normal temperatures.
    still hard to kick start. jetted it 2 steps richer to 118 main, runs very well.
    Now at the 30 degree to 40 it is very hard to start and I need to put the choke on and crank a while with throttle then back off and it will sometimes start. it does not want to keep running and seems to flood out very easily need to use starting fluid after it sits for a while.
    5-40 rotella in it. and no air leaks that I can find.
    any ideas.
    mike
    Senior Member rm_hm's Avatar
    1,619
    Hope one of these links helps
    http://tw200forum.co...5/ShowPost.aspx
    https://www.google.c...iw=1680&bih=941
    Friends don't let friends buy 1987 TW's
    Jun 2011
    71
    thanks for the links.
    does anyone have a blow by blow for the kick start procedure?
    mike
  1. TW problems
    By marc1n5 in forum Technical Help
    Last Post: 05-11-2013, 03:57 PM
  2. Starting my new bike for you......
    By Revolverman in forum General Discussion
    Last Post: 05-25-2012, 06:41 PM
  3. Starting Problems
    By MojoJojo in forum Technical Help
    Last Post: 10-21-2011, 12:02 PM
  4. problems with web cam
    By phazer in forum Technical Help
    Last Post: 08-19-2011, 05:04 PM
  5. Just got my first TW, having some problems
    By destroyingangl in forum Technical Help
    Last Post: 04-26-2011, 09:07 PM
