Off idle stumble? Or carb farts?
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Twowheeler
Thread: Off idle stumble? Or carb farts?
    Member Twowheeler's Avatar
    Jan 2013
    Jacksonville FL
    79
    So I re-rebuilt the carb today. Didn't replace all parts but most.
    The bike runs fine threw the gears, starts right up but the idle I just caint seem to tune.
    I did adjust the pilot screw accordimgl but it seems as if at idle the bike stumbles and chokes and hesitates.
    Is this symptom called an "off idle stumble".
    I will say how ever the pilot screw oring is a little worn and I will be replacing that. Try that tomorrow.
    I'm kinda stumped.
    Anyone ever have the same issues.
    And I cannot say that before the rebuild that it stumbled at idle cause it wasn't running when I got it.
    Jan 2013
    Jacksonville FL
    79
    Soo,
    Replaced the oring and readjusted pilot screw. It's better, no coughing or hesitation at idle but its just not 100 % dialed in yet,
    Butt I did manage to sneak in ye another mod.
    retmotor likes this.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    NICE!!
    Aug 2011
    Cayce, SC
    3,109
    I did the same thing except I drilled the hole higher up so that I dont have a spring to lose. Ask me how many times ive taken my seat off since I did it over a year ago... ONE! Lol
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Jan 2013
    Jacksonville FL
    79
    Ahhhhh. Figures
    Sep 2011
    Southcoast MAsshole
    2,661
    just tie some fishing line to the spring and the frame and you'll be good
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    734
    that looks cool, just took my seat off to pull the battery..is that mod on the forum???
    2005 Tdub
    Jan 2013
    Jacksonville FL
    79
    Quote Originally Posted by Tuber View Post
    Yeah. I stole the idea from some one on here
    I basically cut the head off a longer bolt then drilled a hole for the pin. Easy peasy
    Jan 2013
    Jacksonville FL
    79
    So I really dialed in my carb today with some new parts. One of which was an up size in jet. I did a #118 from a 114 and also opened up the screw so the throttle cable would open up all the way. I for sure now will be doing the shim mod
    Just thought I'd share and highly recommend to rejet. I'm sure conditions and atmosphere play a roll. Soo to all the southeast coasters a #118 and your good.
  1. 91 TW 200 will idle, then die out
    By aduboisiii in forum Technical Help
    Last Post: 07-17-2012, 06:28 PM
  2. idle help
    By greendub in forum Technical Help
    Last Post: 06-07-2012, 06:04 PM
  3. 91 TW Carb, or idle problems. tried all suggestions
    By jandjjobst in forum Technical Help
    Last Post: 05-30-2012, 09:28 PM
  4. 2005 carb issues, slow to idle down
    By MrDNA in forum Technical Help
    Last Post: 10-02-2011, 05:28 PM
  5. sputter and stumble
    By T Dubble D's in forum Technical Help
    Last Post: 08-22-2011, 10:28 PM
atv stumble off idle
atv stumbles off idle
how mikuni carb off idle stumble
mikuni stumbles off idle
tw200 hesitation idle
tw200 off idle stumble
tw200 stumble
xt 225 yamaha stumbles
xt 250 farts on closing throttle
xt225 stumble off idle
yamaha tw farts
yamaha xt225 stumble
