Breather tubes
Results 1 to 3 of 3
Thread: Breather tubes
    Senior Member nfpgasmask's Avatar
    Nov 2010
    Reno, NV
    500
    So I am down to the last bits of my custom build. I have 3 breather tubes laying on the floor, the last of the parts to go back on. Can someone tell me where they all go?
    I know one of them plugs into the carb near where the fuel line is, and I think one might go on the bottom of the carb, but I have three.
    Thanks!!
    Bart
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    Mine has a vent tube on both sides of the carb and one on the bottom for the bowl overflow. The one on the right side of my carb, has a "Y" fitting in it that also heads up to vent under the gastank.
    There should also be one longer one that is meant to go up to your battery. But if you swapped out your battery for one that doesn't have a vent hole..you won't need it.
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Nov 2010
    Reno, NV
    500
    Ahhh, ok, so there was a breather on the battery then...that's the one that is puzzling me. Yeah, I bought a small gel battery so I shouldn't need that one any more...
    Thanks - Bart
  1. Engine oil cap breather tube replacement
    By zil46 in forum Performance and Customization
    Last Post: 05-10-2013, 11:45 PM
  2. tire tubes
    By josh in forum Technical Help
    Last Post: 01-28-2013, 08:24 AM
  3. Where to buy tubes?
    By Scott Hawkins in forum Technical Help
    Last Post: 08-17-2012, 11:48 PM
  4. Tubes
    By mtkd in forum Technical Help
    Last Post: 02-26-2012, 02:29 PM
  5. Battery breather hose
    Last Post: 07-06-2011, 06:12 AM
