Number of chain links needed?? Time is running short
Results 1 to 4 of 4
    Senior Member bikerjosh's Avatar
    Walnut Creek, CA
    1,066
    Howdy All
    So my swingarm is at a buddies shop who is adding three inches to it, but it is taking longer than expected. My problem is I need to know in advance of getting it back, how many links I'll need to have for the new chain and rear sprocket.
    I'm leaving for a trip on the 27th.
    The particulars: switched from a stock sprocket (45t I think) to a 50t. Adding 3" so figure 5 teeth and 6 inches more swing arm.
    Any ideas, I have a chain breaker and master link pliers.
    Thanks Josh
    Not all men are capable of greatness, but all possess toughness.
    2001 TW a mod or two maybeHidden Content
    918
    Quote Originally Posted by bikerjosh View Post
    Howdy All
    Thanks Josh
    Stock sprocket should be 50t. Nonetheless, to give you an idea I run a 14/47 with a 120 link. Measure 6 inches worth of your existing chain and count how many links and add that to 120, then round up so you can cut to your desired length.
    Sold bike.
    Desert, SoCal
    7,369
    Josh,
    Unless you're an astrphysicist I know of no way to reliably calculate for so many variables in advance.
    My advice would be to get at least a foot of extra chain and when the time comes shove your axle as far forward as possible while still falling on even links, cut the chain and run 2 masters for your trip, if you're that pressed. Cut the chain as short as possible while still allowing enough slack to be in adjustment at the lowest possible position on the snails.
    The longer swingarm will mean shorter practical chain life. Not because the chain will wear faster, but because you're introdicing more wear points, so the overall length will be excede the adjusters quicker. Despit the longer swingarm you still have only the same range of adjustment the stock swingarm.
    To illustrate this, let's say you have a chain of 100 pins (wear points), and each pin wears 1/100" over say 2,000 miles. Total stretch is 1 inch.
    A 150 pin chain would then stretch 1.5 inches in the same number of miles. This is an exagerated example, but in your case you're adding 16-20 pins, assuming 8-10 inches of chain.
    So keep it short as possible initially, so you get the most range of future adjustment that you can.
    Walnut Creek, CA
    1,066
    Thanks for replys. Sorry for the confusion, I must have gone up to a 55 tooth, I ordered five teeth above standard.
    Josh
  1. WTB DID X ring chain links
    By aladdin in forum TW200 Classifieds
    Last Post: 02-27-2013, 04:12 PM
  2. OE Chain Links
    By ebikerman in forum General Discussion
    Last Post: 10-21-2012, 05:38 AM
  3. Chain Guard needed..
    By rastaman in forum TW200 Classifieds
    Last Post: 02-04-2012, 02:57 AM
  4. New 0-ring chain--Are sprockets needed?
    Last Post: 02-01-2011, 09:18 AM
  5. Stock number of links?
    By bikerjosh in forum Technical Help
    Last Post: 10-14-2010, 01:05 PM
