Ricochet skid plate
Results 1 to 5 of 5
    1,110
    Just a quick question about installing a Ricochet engine guard. Do you guys cut off the loop that's welded to the frame where the rear part of the stock plate hooks into? It seems to be in the way of installing the right rear Ricochet mounting tab bolt. I didn't get any paperwork with it.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    I just bent mine up a little, no problem after that.
    Pleasanton, CA
    5,720
    Quote Originally Posted by r80rt View Post
    Same here. Just a couple of hits with a rubber mallet and problem solved.
    1,110
    Thanks. My favorite tool....a BFH.
    *edit* I whacked it up but it still interfered with the screw so I ended up bowing it out of shape with a screwdriver. All is well now.
    6,975
    You will never miss it.
  1. Ricochet skid plate installation
    By sinophilia in forum Performance and Customization
    Last Post: 02-10-2019, 02:01 PM
  2. Ricochet skid plate install
    By David G. in forum Performance and Customization
    Last Post: 07-05-2013, 11:17 PM
  3. removal of the ricochet skid plate for oil changes?
    Last Post: 06-23-2013, 07:15 AM
  4. OEM skid plate
    Last Post: 05-31-2013, 12:46 PM
  5. Ricochet Skid Plate
    By APV1 in forum Performance and Customization
    Last Post: 10-27-2012, 07:57 PM
