Front brake stopping power
Results 1 to 10 of 12
    Member ebikerman's Avatar
    Jun 2012
    Fitzgerald Georgia 31750
    50
    My bike is a 2006 TW200 with 700+ miles. Bought it a few months ago. I would like to increase the stopping power of the front brake a little. Seems weaker than my other bike (Honda 250 Rebel). Has anyone done this? Once I had disc brake problems on a Yamaha 4 wheeler Warrior and fixed it by simply changing the brake fluid. Any ideas would be appreciated....Dan
    Desert, SoCal
    7,369
    Mostly it is what it is.
    Your Rebel has bigger brakes, front and rear.
    Mackbig markets a larger brake rotor, but aside from that and possibly a more rigid brake line the isn't a lot you can do with the stock hardware.
    Hailey, ID
    3,340
    Quote Originally Posted by Dan P View Post
    It's possible that a bike that sat for that long would have picked up some water in the brake lines, changing out the fluid with fresh is a good idea anyway every three to five years depending on the average humidity of your region.
    A 2006 should have a front disc, and it's also possible that the pads are glazed or dirty, take them out and sand lightly with 320 on a very flat surface. My 2010 will lock the front tire no problem....actually at 60 maybe it would be a problem.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Desert, SoCal
    7,369
    +1
    One other possibility is that the P.O. put a set of one of the latest "gimmick" pads on it. Some of these are born with thinner pad material than stock and can give the same brake lever feel as worn-down pads.
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    Quote Originally Posted by Rocky View Post
    +2
    I changed my brake fluid and saw smoother action in the level and better braking over all. Its worth the couple bucks for the brake fluid and the 5 minutes change it out.
    -Szj
    2001 TW
    Jun 2012
    50
    I am going to chnge the brake fluid as suggested.....Thanks all
    Germany, Werdau
    1,014
    You can also mount a steel brake line.
    This will give you an better performance too.
    And if you still want more brake performance, than you can change from the 220 disk to my 320 disk.
    Jun 2012
    50
    Quote Originally Posted by macbig2k1 View Post
    Please tell me about your disc. Diameter and do you need a different caliper? THANKS....Dan P
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    I second the braided hose ("Steel brake line") - it makes a suprisingly big improvement. Much 'snappier' action. Replace your fluid and seals at the same time.
    Germany, Werdau
    1,014
    You will find a lot of information about the "320mm brake disk kit" in this thread:
    https://tw200forum.com/index.php?/top...sseted-into-it
    And here's my post from today with the pictures from my new/better adapter for the brake caliper:
    https://tw200forum.com/index.php?/top...550#entry65550
  1. Front brake '99 - '01
    By dutchbat in forum Technical Help
    Last Post: 05-25-2013, 05:46 AM
  2. WTB Front brake line
    By xdac in forum TW200 Classifieds
    Last Post: 06-14-2012, 09:34 PM
  3. Front brake rotor
    Last Post: 12-02-2011, 08:15 PM
  4. front brake lever
    By RisingSun in forum Technical Help
    Last Post: 10-11-2011, 01:18 PM
  5. WTB - Front (brake) hub.
    Last Post: 09-24-2010, 01:14 AM
front brakes are stopped up on yamaha four wheeler
tw200 improve front brake
