Possible new TW200 carburetor setting.
Results 1 to 10 of 15
Like Tree23Likes
Thread: Possible new TW200 carburetor setting.
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    147
    I have not pulled the trigger yet, still very ambivalent about the reliability of a carbureted bike, but that's my issue.
    I have a question: I've read about the brass plug that has to be drilled out in order to adjust the fuel mixture screw. Two turns counterclockwise I believe.
    Does this adjustment have to be made regardless of the altitude the bike lives at or only for bikes that live at high altitude? Mine, if I buy one, will live in SoCal. Thank you for your time.
    jtomelliott49 likes this.
    Senior Member ToolmanJohn's Avatar
    Nov 2016
    Bristol Connecticut
    308
    Carburetors in general are very reliable. Carburetors last nearly forever. If you rebuild every couple years, they are cheap and easy to work on, and super reliable. Always drain the fuel system if you aren't riding for a few months (storage). This will greatly reduce the chances of varnish build up in the fuel/air passages. And replace the carb needle once every couple years in the float bowl and you're all set.
    You can bump start of kick start the carburetor bikes. That's not possible on a fuel injected bike unless the battery and starting system is in good shape. A dead battery on a injected bike means it's NOT starting. Then you need a friend with jumpers at a minimum.
    My bike is carburetor and I now carry jumpers, simply because I was on one ride where a guy on a 4 stroke killed his battery MANY times!! Something was seriously wrong on t hat bike, and two other riders played musical batteries for the majority of the ride when he stalled it or stopped the engine without thinking. No one had jumpers. And made me think about the hour plus I spent standing around while they removed seats and swapped batteries around to charge the dead one in a kicker bike until he killed it again. LOL....
    I guess the take take away is regular maintenance is important. But it was not that guys fault really, he was on an unfamiliar rental.
    Lostrider88 and jtomelliott49 like this.
    2017 Beta Xtrainer 300 - Suspension modified for height
    2013 Yamaha TW200 (Sold but not forgotten, possibly in the future when space permits)
    2007 Kawasaki Ninja 650R (sold) Fun for a year, then mega garage DUST collector
    1985 Honda CB650SC Nighthawk (sold) FUN - but became a dust collector
    1984 Honda CB450SC Nighthawk (sold) Primary transportation for almost 5 years
    Various other 2 wheel rolling junk not worthy of mention....
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,116
    Quote Originally Posted by Cerberus View Post
    Cali bikes come with the carb adjusted lean just so they can pass emissions testing. Once the plug is removed the correct setting is to run the screw all the way in to bottom it out and then back it out 2 full turns. some slight tweaking after this might be necessary but they must be done while the engine is at operating temps. Keep in mind that my advice is based only on the older style carbs between 1987-2000 and I am not all that familiar with the new model carbs. Others here who are out west could have differing advice. Adjusting for altitude seems to only be a necessity if you get above around 5,000 feet or more.
    1987 Yamaha BW350 Big Wheel
    Aug 2018
    San Diego, CA
    147
    Thank you Toolman and GaryL, I appreciate your time. I’m thinking maybe I need to grow a pair, buy this thing and maybe learn how to adjust stuff, that would be a novel idea, wouldn’t it? One more question if I may: is this brass plug difficult to locate or can it be reached easily? Thanks again for your help.
    Jun 2013
    Forestburgh, NY
    8,116
    If the plug is there and has not yet been removed it is fairly easy to get out. On all of my Old Style carbs that had the plug there was a tiny hole drilled in it from the factory. I used a very sharp, pointed self tapping screw and turned it into the tiny hole just enough to get a bite and wiggle the plug out. On the old carbs the plug is located on the bottom and between the float bowl and cylinder and it is a PITA to get to if the carb is on the bike. You can actually loosen the boots on both sides and turn the carb without completely removing it. On the engine side the joint the carb goes into has an alignment tab at the top so the carb needs to be pulled out a bit before you turn it. Again, I don't know the new style carbs and if they have the same conditions.
    18,962
    The new style carbs have the same condition and same solution.
    The brass plug is very thin and easy to remove. Many never make any adjustment though and just ride their bikes a little leaner than optimum, and thus a little weaker than they can be.
    As far as elevation goes I have been pleased with stock California jetting with the mixture screw at 2 1/4 revolutions out riding from sea level to over 11,000 ft.
    Aug 2018
    San Diego, CA
    147
    Thanks Fred and GaryL. Great help. Now I have a tarting point.
    Hailey, ID
    3,395
    As far as the pilot needle setting goes, it will be a little further out at sea level than altitude. At 6,000 feet I have mine out 2 turns. It is not all that sensitive as Fred points out, but the factory setting is usually 1.5 turns, way too lean for good running between idle and half throttle.
    As far as reliability, I would NEVER trust a fuel injected bike when I go alone into the boondocks. The TW is the most reliable bike I have ever owned in 50 years of riding and really easy to maintain. I would ride it across Mongolia....alone.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Aug 2018
    San Diego, CA
    147
    I bet they can probably fix it over there...haha
    18,962
    +1 for a carburetor's simple reliability when away from civilization. Gravity always seems to work to supply fuel to carbs while fuel injected bikes absolutely need a working high pressure pump and clean injectors.
    By bias is admittedly flavored by last weekend's FI fuel pump failure that left me stranded after dark in a neighboring state.
    We did have a Mongolian TW rider for a while here, he explored the steppes from his home in the capital of Ulaanbaatar then disappeared never to be heard from again...
    I did know an exploration geologist who worked far to the west and far from modern living...had no TW though...rode yaks, ate yak blood, yak milk, and yak cheese and really, really missed American hamburgers.
    admiral and jtomelliott49 like this.
  1. Base Line Carb needle setting, PICS of Carb? 1989 TW200
    By YankeePrepper in forum Technical Help
    Last Post: 04-24-2015, 06:04 AM
  2. Possible Carburetor Issue
    By bikelover in forum Technical Help
    Last Post: 09-05-2013, 09:58 PM
  3. Good youtube on setting valve and exhaust lash
    By OSOK in forum Technical Help
    Last Post: 09-05-2013, 06:35 PM
  4. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 09:24 PM
  5. setting an example
    By phelonius in forum Test Forum
    Last Post: 12-01-2010, 10:48 AM
