Clutch Life
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By elime
Thread: Clutch Life
    Feb 2017
    Waretown NJ
    556
    Clutch Life
    How many miles are you all getting out of clutch plates? Mine isn't slipping yet. I was curious. Are there 4 or 5 fibers and I'm assuming the metal plates are steel as opposed to aluminum? I try to be gentle with the clutch as there isn't a need to abuse it like a mx bike clutch. I'm pulling tall gearing and I don't want to slip in 5th when I'm riding it at speeds I shouldn't be.
    87 TW
    Senior Member YamTW87's Avatar
    Mar 2017
    Greece
    157
    I can't help you with a clutch life estimate.
    But by using heavy duty stiffer clucth springs, like the ones EBC makes, you will prolong clutch life.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    984
    Because of the low horsepower of the TW200.... The clutch should last a very long time unless it is seriously abused !!
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    7,001
    The clutch in my first TW started slipping a little bit so I first installed shims on the clutch springs and when it started to slip again I installed heavy duty springs. Both fixes worked for a while but eventually it needed a new clutch. I went with the Barnett Kevlar clutch. Cost twice as much as the cork one and worth every penny. That TW now has a total of 32K miles on it. I think I installed the Barnett around 25K miles but that was after I used Shell Rotella oil.
    Mel likes this.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,488
    34000kms on my 99 with 15/47 gearing and never an issue and I don't baby it.
  1. Is a sticky cold clutch just part of TW life or is there a fix
    By DougDotyTW200 in forum Technical Help
    Last Post: 05-29-2018, 05:57 PM
  2. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 07:24 AM
  3. chain life
    By brent morley in forum General Discussion
    Last Post: 03-14-2012, 01:28 AM
  4. Life in New Mexico
    By peruano in forum Off-Topic
    Last Post: 09-16-2011, 12:53 PM
  5. Look at Life - Scooter Commuter, 1962
    By rm_hm in forum Off-Topic
    Last Post: 01-11-2011, 03:53 PM
