YTM200 piston ?
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Like Tree3Likes
Thread: YTM200 piston ?
    Poway CA.
    2,100
    Quote Originally Posted by Kwizard
    Howdy Y'all,
    Can anyone confirm or deny that a Wiseco YTM200 high compression piston will fit the TW200 cylinder?
    I appreciate ya
    The midget fortune-teller who escaped from prison was a small medium at large.
    The YTM 225 piston fits the TW crank and the TTR225 cylinder. Not sure of the YTM200?
    Ronnydog
    Germany, Werdau
    1,014
    I can confirm, it will fit.
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    Quote Originally Posted by macbig2k1 View Post
    Can the stock TW200 barrel be bored out to 71mm?
    Member RingSteel's Avatar
    Jan 2012
    Cypress, TX.
    56
    "High compression piston". This is an interesting thought. Does anyone know if there is a down-side to installing a higher compression piston in the TW200?
    Germany, Werdau
    1,014
    Quote Originally Posted by tw200sgp View Post
    The biggest possible size is 70mm for the original 200 cylinder.
    You have to install a bigger sleeve, if you want 70.5 (or bigger) piston.
    The biggest possible size is the 73mm piston from Wössner piston. These pistons should be also available in the US.
    -> You can contact me, if you can not find a US-reseller/dealer for Wössner.
    Germany, Werdau
    1,014
    Quote Originally Posted by RingSteel View Post
    Please use the service manual. Everything is written into it.
    It doesn't matter which piston do you use (original or high compr.), the procedure is always the same.
    Aug 2011
    Cayce, SC
    3,109
    What kinda cc's would it be with a 73mm bore? Just curious...
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Germany, Werdau
    1,014
    233,1 ccm with the 200 ccm crank
    242,8 ccm with the 225 ccm crank
    Aug 2011
    Cayce, SC
    3,109
    How much wear do you have on the cylinder? I know that I could get away with a hone but that's because I only have 3700 miles on my 2010.
    Aug 2011
    Cayce, SC
    3,109
    So I could turn my 200 into a 233cc beasty with a re-sleeve?! Is the mouth of the stock case wide enough to accept a 73mm piston? If so, I may have another winter project? Has anyone done this before? Is this or a 72mm bore the set-up of the european 225's?
  1. Dirty piston?
    By HercJerk in forum Technical Help
    Last Post: 07-06-2016, 05:48 PM
  2. Buying Piston Rings
    By canadainshiver in forum Technical Help
    Last Post: 05-05-2013, 11:37 PM
  3. tw piston?
    By n2o2diver in forum Technical Help
    Last Post: 05-02-2013, 03:49 PM
  4. Piston Dropped at 5700 km
    By Drapes in forum Technical Help
    Last Post: 07-25-2012, 07:29 PM
  5. Cylinder and Piston
    By Desertwndrr in forum Performance and Customization
    Last Post: 01-06-2011, 02:46 PM
2010 tw200 cylinder
cantw200cylinderbebored
tw200 piston
tw200 wiseco piston
weisco piston for tw200
what is the piston to cylinder clearance for yamaha moto4 200
wiseco piston for tw200
yamaha 200 piston clearance
yamaha tw200 stock piston
ytm 200 piston clearance
ytm piston in tw200
ytm200 piston
