Slipping Clutch
Results 1 to 5 of 5
Thread: Slipping Clutch
    Junior Member yawabala's Avatar
    Aug 2012
    Nairobi, Kenya
    22
    What engine oil do you guys use for your t-dub engines?i recently sarted using shell 15-40w and the clutch has started slipping.
    Aug 2012
    Nairobi, Kenya
    22
    Quote Originally Posted by Kwizard
    Howdy, and welcome to the forum. I think your oil choice is OK; but a lot of us use synthetic. I've been using Castrol products for 30 years or so(actually let's make that over 50 years; because I used to use Castrol caster oil to mix in my Gulf hi-test for my 2 strokes)(I love that smell to this day). That being said; your oil is probably not the cause of your clutch slipping. Look and search our tech forum, and you'll probably find your answer shortly. There is also a full manual, and supplement on that forum. If you need help from us; you'll need to tell us your year model and smileage.
    Ride on Daddy-O
    PS: Are you using a motorcycle specific oil? I hope so!
    Aug 2012
    Nairobi, Kenya
    22
    It's a 96 model,thanks for your help
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Most automotive oils have friction modifiers in them that can make your clutch slip, it's best to use motorcycle specific oil in your bike.
    Senior Member dubstep's Avatar
    Oct 2010
    Hong kong
    453
    yeah car oil can make your clutch slip.. qwerty gave some good advice on this.. change oil - and leave your clutch lever pulled in when ever u can whilst parked ( or over night say ) by tying it back to the bars.. fixed it for me after a couple of oil changes in quick succesion. ( like changed oil twice in a week )
    car oil no good for wet clutches...
    2001 TW200 - supertrapp stubby exhaust
    1996 CRM 250 - 2 smoker - FMF exhaust
    1998 Honda CB600 Hornet - ( a.k.a Honda 599 ) - micron , ohlins rear - CB600F3 front forks..
  1. Slipping clutch...????
    By rastaman in forum Technical Help
    Last Post: 07-29-2013, 11:09 AM
  2. Another Slipping Clutch
    By FnMag in forum Technical Help
    Last Post: 06-07-2012, 09:21 AM
  3. clutch slipping
    By dubstep in forum General Discussion
    Last Post: 02-03-2012, 11:57 PM
  4. Clutch slipping!
    By AttitudeXX in forum Technical Help
    Last Post: 10-18-2011, 08:10 PM
  5. slipping clutch
    By tpar1220 in forum Technical Help
    Last Post: 10-01-2010, 10:37 PM
