1994 TW Carb question
Results 1 to 6 of 6
Like Tree5Likes
  • 2 Post By GaryL
  • 2 Post By GaryL
  • 1 Post By GaryL
Thread: 1994 TW Carb question
    Member ldw72120's Avatar
    Oct 2011
    Central Arkansas
    69
    I let my TW set to long and it will not idle. I disassembled the carburetor to clean it and have a question about the coasting enricher. I tried to remove the brass mechanism but was unable to do so. My question is, should there be any movement from the "button" on the enricher?tw carb side view.JPGtw enricher.JPG
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,130
    YES! The plunger should move freely. They are a PITA to get out for replacement but if you carefully use a small and sharp chisel with a few taps from a small hammer you can free them for removal. I have one out now and a new one going in today.
    1987 Yamaha BW350 Big Wheel
    Oct 2011
    Central Arkansas
    69
    What symptoms would you experience to cause you to replace the enricher?
    Jun 2013
    Forestburgh, NY
    8,130
    Quote Originally Posted by ldw72120 View Post
    There is a tiny spring behind the brass plunger. It that plunger does not move freely and pop back when you push it in it is no good. There is a diaphragm over that plunger with a larger spring and then the cover. It all works together. Check the rubber on the diaphragm for splits or cracks. I think if all is good elsewhere in the carb and only the enricher is bad you will likely have backfiring on deceleration.
    Purple and Smitty Blackstone like this.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    378
    Hello,
    The piston is fixed on the membrane
    Jun 2013
    Forestburgh, NY
    8,130
    Quote Originally Posted by christddel View Post
    Hello,
    I have no idea where you got that picture info from but I just replaced that exact part in one of my carbs and there is no such piston fixed on either side of the diaphragm. Your first picture on the left shows the piston I referred to and there is a tiny spring under it allowing it to move in and out under spring pressure. I have never seen a diaphragm with that attached plunger in an early model TW carb. What you are showing is the correct parts for the newer carb that came on bikes after 2001 with a completely different carb. Go here https://www.partzilla.com/catalog/ya...lifornia-model. You need part #32 Diaphragm set for your carb which is the same for all TW carbs from 1987 through 2000. In 2001 the carb changed and the parts are different.
    Smitty Blackstone likes this.
  1. How do I test my charging system on my 1994 TW
    By My ridge in forum Technical Help
    Last Post: 05-15-2018, 02:00 PM
  2. 1994 TW for sale, one of a kind
    By Boedy in forum TW200 Classifieds
    Last Post: 11-23-2016, 10:24 AM
  3. 1994 TW 200 in Michigan $1,500 SOLD
    By snowman485 in forum TW200 Classifieds
    Last Post: 05-02-2016, 11:38 PM
  4. Carburetor Style of 1994 TW
    By dakman74 in forum Performance and Customization
    Last Post: 08-17-2011, 08:41 AM
  5. 1994 tw when you gun it real hard it grinds
    By Daltoncoody in forum Technical Help
    Last Post: 06-04-2011, 09:59 PM
