Cylinder head from YFM250 - O-Ring needed?
Results 1 to 2 of 2
    Junior Member Franconian's Avatar
    Nov 2018
    1
    Hi,
    I recently bought a new cylinder head kit for a very good price for a YFM250. It fits perfectly, however the O-Ring (file attachment No. 2) does not fit well. The bulge on the YFM250 head is considerably smaller, if I fit the O-Ring it does not seem to sit properly and I am worried that it will leak. Is the O-Ring absolutely necessary? Maybe the YFM250 has a smaller one?
    Any thoughts, suggestions?
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    378
    Hello,
    The seal is identical to more Yamaha engine...XT225, YFM200/250, TW200..
    https://www.bike-parts-yam.com/yamah...rts/9321072529
    If you do not put it, the contact surfaces of the engine parts must be very clean.
    With a new seal and a little sealant...
    Personally , I will disassembly the sleeve of the cylinder to rework the groove the oring in the aluminum block
  1. Replies: 10
    Last Post: 11-28-2018, 11:48 AM
  2. Cylinder head and cylinder assembly problem
    By jgaff in forum Technical Help
    Last Post: 07-05-2017, 11:23 AM
  3. Replies: 9
    Last Post: 10-27-2016, 01:23 AM
  4. Replies: 10
    Last Post: 05-15-2016, 07:10 PM
  5. cylinder head
    By christddel in forum Technical Help
    Last Post: 02-28-2011, 05:38 PM
