Pulled Push Rod #1 from the clutch assembly
Results 1 to 5 of 5
Like Tree12Likes
  • 1 Post By kltrkmpf
  • 2 Post By TW-Brian
  • 3 Post By TW-Brian
  • 5 Post By kltrkmpf
Thread: Pulled Push Rod #1 from the clutch assembly
    Member kltrkmpf's Avatar
    Dec 2014
    Singapore
    45
    Question Pulled Push Rod #1 from the clutch assembly
    Hi guys,
    Good day! I pulled this Push Rod #1 from the clutch basket module by accident, is it OK if I just push it back into the hole it came off from?
    This push rod #1 from the middle of the clutch assembly
    It is the part indicated here in the diagram (Blue arrow). Apparently there's a ball (red arrow) behind it. Should I be worried? Or can I just put the rod back?
    Thanks in advance guys for responding.
    Best regards,
    Gunn
    littletommy likes this.
    Pleasanton, CA
    5,777
    If you still have the ball bearing, just put it back together the way it came apart. If you don't have the ball bearing, you will need to get a replacement.
    Dec 2014
    Singapore
    45
    Thanks Brian. I just want to know if the ball would came off easily. I don't have the tool to pull open that part to inspect...
    Pleasanton, CA
    5,777
    This is all you need to remove the ball bearing, or you could just tip the bike over to the right side (but be careful that the ball bearing doesn't roll away and get lost).
    Dec 2014
    Singapore
    45
    Thanks so much Brian! managed to put everything back together, thanks again!
  1. Clutch indentation rod is bad from factory
    By TW2000 in forum Technical Help
    Last Post: 04-30-2017, 11:14 PM
  2. Wont start in gear with clutch pulled in
    By Ledmelon in forum Technical Help
    Last Post: 06-26-2016, 06:52 PM
  3. Replies: 12
    Last Post: 06-18-2015, 05:41 PM
  4. o ring for clutch push rod
    By c.salt in forum Technical Help
    Last Post: 06-21-2014, 07:20 PM
  5. clutch push rod adjustment
    By TheRedRider in forum Technical Help
    Last Post: 08-03-2013, 07:04 PM
