Tire Inner Tubes
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By RockyTFS
  • 1 Post By RaZed1
Thread: Tire Inner Tubes
    Junior Member philo's Avatar
    Nov 2018
    22
    Tire Inner Tubes
    I'm sure there is a lot of good info on tire inner tubes. Could someone give me a link. The search isn't coming up with much.
    Thanks
    Senior Member YamTW87's Avatar
    Mar 2017
    Greece
    156
    Here is one I just found.
    Also:
    Front tube Yamaha Part Number: 94212-18188-00
    Rear tube Yamaha Part Number: 94218-14251-00
    Bridgestone and probably Dunlop make tubes for TW tires,ask a dealer.
    I am not sure about the size of them.
    Nov 2018
    22
    Thanks, I was hoping for something Heavy Duty (puncture resistant....)
    Hailey, ID
    3,404
    RideOn. Search the forum: site:tw200forum.com RideOn
    Gulfrider likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    Quote Originally Posted by philo View Post
    Thanks
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1, this is the front tube I used.
    2005 TW200
    2007 Sportster 1200
    Mar 2015
    Ynys Môn
    4,631
    https://www.tw200forum.com/forum/tec...e-choices.html
    No links but they change over time anyway .....
    - Hidden Content
    Senior Member RaZed1's Avatar
    Oct 2015
    297
    Any 18" tube will work for the front- 120/130 width is an extremely common rear tire size on dirt bikes.
    The rear is kind of an oddball size but Bridgestone does make a thicker HD version.
    Thicker tubes add significant rotating mass, which has a noticeable effect on performance and stability (particularly in the front).
    Unless you are running very low tire PSI and on nasty trails, I'd advise to stick with standard tubes. Thicker tubes do nothing to resist road debris puncture (nails ect) anyway. HD tubes help resist pinch-flats from rough terrain at low pressures/aggressive riding.
    Slime or Stan's are far more effective resistance to road punctures. I mean you can still pick up a nail, but it'll substantially slow the leak so you can make it home and not stuck on the side of the road.
    philo likes this.
  1. What Inner Tube For My Duro Tire
    By Devils Advocate in forum Performance and Customization
    Last Post: 04-28-2015, 08:41 PM
  2. tire tubes
    By josh in forum Technical Help
    Last Post: 01-28-2013, 09:24 AM
  3. GUYS WITH ATV TIRES, CHECK THIS INNER TUBE OUT.
    By slowpoke in forum General Discussion
    Last Post: 12-28-2011, 09:44 PM
  4. Inner fork tube
    By apodhajski in forum TW200 Classifieds
    Last Post: 10-16-2010, 01:02 PM
