Installing TTR225 clutch
Results 1 to 7 of 7
    Senior Member yz250f4ever's Avatar
    Dec 2012
    Southern, CA (SO CAL)
    315
    hey kwizard, whats the bonus with installing a TTR225 clutch pack?
    ALEX-
    My Current Rides:
    DIRT:
    2013 yz450F (race bike)
    2011 Yz450F (practice bike)
    2008 Yz250F (full mod)
    2005 TTR125 (full mod Gf's bike)
    Street:
    2009 DRZ400SM (full mod)
    2009 qlink XF200 (sumo build)
    2007 SDG 140cc big bore (supermoto)
    Hidden Content Hidden Content Hidden Content
    Poway CA.
    2,100
    \quote name='Kwizard' date='22 January 2013 - 07:08 AM' timestamp='1358867311' post='66023']
    You gain an extra plate set, and reportedly a no mod bolt in.
    [/quote]
    There is a dif in the end shafts.
    Ronnydog
    Germany, Werdau
    1,014
    The problems are starting here.
    The TTR does have a other toothing as like the TW.
    If you want the 6 disk clutch, you have to install the TTR shaft.
    But the TTR shaft does have a 6 speed transmission.
    You will need a 6 speed output shaft.
    The next problem, the 6 speed transmission does have a shorter output shaft as the TW.
    The summary
    What you need:
    - inner and outer clutch basket from a 6 disk clutch
    - 6 speed transmission
    - and you have to find a way to enlarge the outputshaft
    Sebastian
    Poway CA.
    2,100
    Quote Originally Posted by Kwizard
    I'm thinking I'm going to give this little bright idea of mine a pass. Thanks guys for all your input. Let's see now; what's next?
    Add some washers if you want better hook up.
    Ronnydog
    Poway CA.
    2,100
    To the spring retainer bolts?
    I have been running this for years on my TW226 with a stock clutch.
    Ronnydog
    Germany, Werdau
    1,014
    You can also install stiffer springs.
    The following is one of my company secrets.
    I can tell you this, because I can not make good deals with you:
    -> shipping is expensive
    -> USD-EUR exchange rate is bad for you
    These reasons will make for you standard parts a bit expensive.
    The clutch springs from EBC are 10% stiffer, as the OEM springs.
    The fitting springs for the TW does have the number CSK052.
    -> This is not the secret
    But I've found a other set of fitting springs.
    CSK002
    These springs will fit perfect on the 2001 and newer models, because Yamaha has changed the pressure plate a little bit.
    All other bikes will need a small modification. There must be removed a bit material from the pressure plate, because the spring diameter is a bit bigger (~0.8mm bigger, but you don't have to remove so much -> ~0.4mm).
    Sorry, I not describe it better. I hope, you understand what I try to say.
    I've made a small calculation to get the spring rate from the different clutch springs.
    -> I don't know the exact value of "G = modulus of rigidity", but I use 81.500 N/mm² as basic value for the calculation.
    13,40 N/mm² -> OEM spring
    14,74 N/mm² -> CSK052 -> 10% stiffer as OEM
    15,69 N/mm² -> CSK002 -> 17,1% stiffer as OEM
    I've ordered some other springs from EBC and I want to check these springs too.
    Germany, Werdau
    1,014
    I wish your store was here in the states.
    Trust me, sometimes I have the same wish.
    There are much more TW diver in the US as in the whole European Union.
    -> I don't know it, but I am absolute sure about this fact.
  1. ttr225 motor in a tw?
    By stan in forum Technical Help
    Last Post: 11-28-2012, 06:28 PM
  2. ttr225 header
    By kripton in forum Technical Help
    Last Post: 06-04-2011, 04:43 PM
  3. TTR225 engine in a TW200, extended front sprocket shaft?
    By Skullhag in forum Performance and Customization
    Last Post: 05-01-2011, 06:27 PM
  4. Installing AfterBurners
    By Rohnsman in forum Performance and Customization
    Last Post: 12-25-2010, 06:42 AM
  5. ttr225 piston in a tw200 cylinder
    By racerx in forum Performance and Customization
    Last Post: 08-18-2010, 03:22 PM
01 yamaha ttr 225 clutch removal
2001 ttr 225 hamaha clutch videos
aftermarket ttr225 clutch
how to adjust ttr225 clutch
how to replace clutch on ttr225
howtoadjustclutchonattr225
spring rate ttr225
ttr 225
ttr 225 clutch repair
ttr 225 clutch replacement
ttr225clutch
yamaha ttr 225 clutch instalation
