Clunk under seat...what is it?
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree19Likes
Thread: Clunk under seat...what is it?
    Senior Member ZacoWacko's Avatar
    Feb 2018
    SW, Oklahoma
    112
    So when bouncing up and down on the bike (or going over bumps), i get a clunk, which sounds like its coming from under the seat. I think at least. Hard to tell when you are on the bike. I'm thinking rear shock, but, was wondering if anyone has had this before.
    Somewhere i have a video of it, i'll try and get up later, hopefully. Lol
    Dec 2017
    Western Washington
    216
    Possibly the battery is not secured or the bushings on the shock are worn out.
    Purple, Dryden-Tdub and Tweaker like this.
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400’s, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    Senior Member buellzebub's Avatar
    Oct 2015
    Breedon on the Hill, UK
    343
    Could be lower shock mount, it's just a plain pin through 2 thin lugs on the swingarm. But check also that the top mounting bolt is tight.
    Tweaker likes this.
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    Unlike your girlfriend it is ok to have a buddy jump up and down on her while you watch.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,123
    Make sure all of your motor mounting bolts are secure. There should be a rubber pad under the rear fuel tank mounting bolt. Any such clunking should be seriously investigated and the source found before you do much riding.
    Tweaker likes this.
    1987 Yamaha BW350 Big Wheel
    Feb 2018
    SW, Oklahoma
    112
    I'm thinking possibly shock too. I looked and tried to move it by hand and all seemed good. I didnt think to look at the tank. I did switch my tank to an xt tank, so i'll look there again. Also check the motor mounts. Been too cold to ride it anywhere but around the field, so no long trips planned. Did have fun in the snow the other day.
    Feb 2018
    SW, Oklahoma
    112
    Not sure if this will work or not. Let me know if you can see video from this link
    https://photos.app.goo.gl/XD9BkB3vbcwk96Jq8
    GaryL and Fred like this.
    Senior Member Rickhem's Avatar
    Nov 2014
    Schoharie County, NY
    110
    Ive experienced this same clunk noise as well. It sounds to me like there is something loose under the tank that pops up and taps it when going over a bump. Only happens when there is a lot of force hitting the bump, not little ones.
    I thought about it being the battery, but it doesn't seem like that to me (could be though). I've checked for anything loose and not found anything that could be making the noise. I've even thought it might be a cable slapping against something metal (clunk sounds like metal contact to me) but that doesn't seem to be it either.
    Still a mystery on my bike, let us know if you discover anything.
    2009 TW200
    2000 V-Star Classic
    1986 HD Sportster (sold)
    1975 Yamaha DT125 (sold)
    Jun 2013
    Forestburgh, NY
    8,123
    Quote Originally Posted by ZacoWacko View Post
    Video works without sound. I can't see from here what might be causing the clunk. Some members have had issues with the steering bearings in the tree going bad and reported clunking. I think I would remove the tank and try your hop test again without the tank.
    Mar 2015
    Ynys Môn
    4,630
    Unless it's the forks - but that's more like a "clack" .....
    - Hidden Content
  1. Clunk from instrument panel at every bump?
    By PalmStateCrawler in forum Technical Help
    Last Post: 11-07-2017, 05:47 AM
  2. Clunk
    By 1RobAusdemore in forum Technical Help
    Last Post: 06-24-2014, 10:51 PM
  3. Clunk and Lunge into 1st..
    By Sferics in forum Technical Help
    Last Post: 04-12-2012, 05:38 PM
  4. front shock has developed a "clunk"
    By misterpepper in forum Technical Help
    Last Post: 10-02-2011, 05:02 PM
  5. Loud clunk when down shifting
    By moneal in forum Technical Help
    Last Post: 06-28-2011, 01:04 AM
