Front Drum Brake Swap to Disk
Results 1 to 5 of 5
Like Tree9Likes
  • 2 Post By ronnydog
  • 1 Post By TW-Brian
  • 6 Post By TW-Brian
Thread: Front Drum Brake Swap to Disk
    Poway CA.
    2,102
    Has anyone made this swap? I’m working on it right now and would like your input?
    A8E55FCA-5726-4286-92AB-675014E9E5FA.jpegRonnydog
    Mel and Badgerflorida like this.
    Pleasanton, CA
    5,775
    I have done it, but it has been a few years. What input do you need?
    Poway CA.
    2,102
    Brake light wiring from the old to the new, do you have any pics?
    Pleasanton, CA
    5,775
    Sorry, but I don't have any pics that would help.
    I swapped the parts from a complete, running 2003 TW onto my son's 1987 TW. So I used the entire front brake lever/master cylinder including the attached brake light cable assembly. I then used the 1987 brake lever/brake light cable assembly on the 2003 for a fat front wheel conversion with a drum brake. I do not remember having any issues with the wiring, so my guess is that the 2003 brake light cable was able to plug directly into the 1987's wiring harness, and vice versa.
    I hope this helps,
    Brian
    Pleasanton, CA
    5,775
    Hey Ronny,
    You could also use a universal hydraulic brake switch that just replaces the banjo bolt on your master cylinder.
  1. Front Brake Issues -disk
    By bikerjosh in forum Technical Help
    Last Post: 08-31-2015, 09:02 PM
  2. Drum to disk brake
    By Fsherfy in forum Technical Help
    Last Post: 10-16-2014, 12:03 PM
  3. FS-- drum to disk conversion parts
    By rvtjonny in forum TW200 Classifieds
    Last Post: 08-30-2013, 04:03 PM
  4. Front disk brake cover
    By abuck40 in forum Performance and Customization
    Last Post: 03-18-2013, 09:52 PM
  5. front disk brake cover
    By mdesheles in forum Performance and Customization
    Last Post: 03-18-2013, 06:58 PM
