I have a 2003 or 4 tw200 that won’t stop leaking gas
Results 1 to 10 of 10
Like Tree27Likes
  • 4 Post By SportsterDoc
  • 7 Post By admiral
  • 4 Post By elime
  • 1 Post By [email protected]
  • 3 Post By Badgerflorida
  • 4 Post By GaryL
  • 2 Post By SportsterDoc
  • 2 Post By Tweaker
Thread: I have a 2003 or 4 tw200 that won’t stop leaking gas
    Junior Member Breckensmith234@yahoo.com's Avatar
    Sep 2018
    Question I have a 2003 or 4 tw200 that won’t stop leaking gas
    If I don’t shut the gas off it will leak a steady drip from somewhere on the carburetor or around it. It has only 1443 miles and I don’t know where the leak is coming from. any ideas?
    Jan 2017
    Southern Nevada
    1,077
    Clean or replace carb float valve.
    Then good idea to change your oil.
    Welcome to the forum!
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Frosty Hollow
    13,174
    As Doc mentions, you're float could be stuck, or some kind of debris in the needle valve area or a bad float needle valve all together.
    Another strong contender for the leaking carb is the o-ring around the needle valve seat (see photo below) could be deteriorated. This happened to my 2005 TW. Another sign was my carb would flood as too much fuel was entering the entire carb not just the float bowl. Mine was leaking out two hoses not just the float bowl drain hose. To get to the needle valve seat, you need to remove the float, float needle valve and then the seat hold down screw. The needle valve seat is held down by the screw.
    Word of caution; the float pin is a one way out and one way back in.
    Here is some more innards photos.
    The photos above are courtesy of jbfla and are not mine.
    7,001
    It may be either or both of the rubber things the red arrows are pointing to. Replace them both.
    Sep 2018
    And also want to add that won’t idle when first started but idles too high when I’m done riding, thanks I greatly appreciate it
    Tweaker likes this.
    Jun 2017
    Milwaukee, WI
    1,301
    Maybe a full carb clean would be in order.
    JBFLA has a great how-to thread https://www.tw200forum.com/forum/tec...-cleaning.html
    Adjusting your mixture screw will probably help with your idle issues, but since you have a leak, doing the full clean would be my suggestion.
    SportsterDoc, elime and admiral like this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,130
    On the very bottom of one of the float pin post you will see a tiny arrow pointing the direction for removal. After you replace and get the new parts into the clean carb it is always a standard practice to shut the petcock lever to the off position when ever you park the bike. Even a clean and new float needle valve can stick and leak your entire fuel tank all over your garage floor.
    1987 Yamaha BW350 Big Wheel
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by [email protected] View Post
    Not wanting to idle could be mixture scew not opened from factory lean setting to about 2 1/2 turns out from gentle seat.
    Idle high could be from vacuum leak around carb inlet to intake. Is boot in good condition? If you remove carb, moisten the boot before gently reinserting.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Dec 2015
    San Diego
    1,865
    Another awesome thread that could be a sticky. I would add when you remove the float pin be very careful not to break the arms where the pins go through try to support and tap carefully with a punch smaller than the hole. Some have drilled the holes slightly bigger so the pin slips out easily. The pin won’t fall out with the bowl on but I would not want the hole too big as slop may affect the float adjustment.
    Member SuperSport's Avatar
    Jul 2017
    49
    As mentioned above, be sure to check your oil for fuel in there. You can normally smell fuel if you sniff at the oil cap. If there is too much fuel in the oil, it can cause poor idle at different temps, and can also burn out bearings.
    Disclaimer: These are my own opinions & not an official statement of Acme Corporation or any Acme employees. Actual mileage may vary. Price does not include tax, title, or license. Some assembly required, each sold separately, batteries not included. Objects in mirror are closer than they appear. If conditions persist, contact a physician. Do not pee into Wind. Call doctor for erections lasting more than 48 hrs; & Guiness Records. If you already pee'd into the wind, change clothes immediately.
  1. Leaking Base Gasket OR Leaking Starter o-ring!
    By JS5owner in forum Technical Help
    Last Post: 11-08-2016, 09:37 AM
  2. Carb leaking gas when gas on and not running
    By Little Brute in forum Technical Help
    Last Post: 06-10-2015, 05:20 PM
  3. Replies: 2
    Last Post: 04-18-2014, 07:17 AM
  4. Gas Leaking from Carb
    By lrotunda in forum Technical Help
    Last Post: 05-02-2011, 11:22 PM
  5. Gas leaking into air box overfill
    By Adam-n-nevada in forum Technical Help
    Last Post: 08-21-2010, 10:47 PM
sportsterdoc
