OEM clutch plate question
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Like Tree49Likes
Thread: OEM clutch plate question
    Junior Member azgsa's Avatar
    May 2015
    PHX AZ
    21
    Recently bought a 2007 TW and the guy said the clutch was slipping a bit when cold (but fine when hot) so I thought I'd just replace the clutch friction and metal plates. I ordered new OEM Yamaha plates from Rocky Mountain ATV*MC (where I pretty much buy all my MC parts from) and I noticed the new metal plates look different than the old ones, new ones aren't symmetrical. The parts fiche says "336-16324-00-00 (replaces part #137-16324-00-00)" so I'm wondering two things, are these plates a newer version that are physically different and if so how are they installed (orientation...)?
    Here are pics of the plates:
    Original:
    New:
    EDIT:
    To avoid having to scroll through the multiple pages for an answer, the answer to my questions were eventually provided by Yamaha USA.
    Me: What is the correct orientation for the new design plates?
    Yamaha USA: Thank you for reaching out to us. These clutch plates should be offset as shown in the image below:
    Me: Any idea what the purpose of the nubs are?
    Yamaha USA: This shape allows more oil to enter between the clutch plates to improve lubrication. Thank you for your inquiry.
    So to sum it up, after installing the first of 5 friction plates in the clutch basket, the first steel plate would be oriented with 'nub' at 12 o'clock position (as shown in image below) then a friction plate then another steel plate with 'nub' at 3 o'clock and so on for all 5 friction plates and 4 steel plates.
    Last edited by azgsa; 12-19-2018 at 07:23 PM. Reason: privide solution to questions in first post so users don't have to look through all posts to find answer
    MidnightRider likes this.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,485
    I don't even know what to say. I just keep staring at it and laughing.
    TW-Brian, Tweaker and Miaugi like this.
    May 2015
    PHX AZ
    21
    Quote Originally Posted by Peterb View Post
    Not the response I was hoping for.
    Darth and Miaugi like this.
    Jun 2017
    Milwaukee, WI
    1,293
    Are they all that way? I’ve never had to do a TW clutch but that strikes me as a defect.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    May 2015
    PHX AZ
    21
    Quote Originally Posted by Badgerflorida View Post
    Yes, all 4 are that way. If you google either the original part number or the superseded one you'll see multiple listings on Amazon and various MC parts suppliers that reference them as the correct clutch plate for the TW and other Yamaha models, and show the one with the 'nub' on one side. I can't find any web reference to questions or installation. Since there are 4 of them I would think the correct way to install would be to orient the 'nub' 90 degrees from each other simply for balancing purposes.
    Darth likes this.
    Dec 2015
    San Diego
    1,865
    Thes e are the low speed eccentric torque optimizer plates. They are meant to be aligned together at the nub when oriented this way there is a “flywheel” effect that increases torque for low speed crawling. JK
    6,999
    Quote Originally Posted by Tweaker View Post
    Does "JK" stand for "just kidding"?
    Tweaker likes this.
    Dec 2015
    San Diego
    1,865
    yes.sounds good though. Or they could be the crankshaft resonance balancer plates for less vibration at top speed.
    elime likes this.
    6,999
    When I first read it I was convinced, you sold me. But then I thought about it for a minute........and I came to the conclusion "NO WAY!" However the "resonance balancer for the crankshaft" sounds like a really good idea.
    Tweaker likes this.
    19,023
    There not for prying up pull tabs on beer cans then?
  1. OEM Handlebars and Skid Plate For Sale
    By nordic1 in forum TW200 Classifieds
    Last Post: 12-15-2017, 10:04 PM
  2. Replies: 12
    Last Post: 04-23-2016, 11:19 AM
  3. Replies: 10
    Last Post: 05-28-2015, 01:16 AM
  4. OEM skid plate
    Last Post: 05-31-2013, 01:46 PM
  5. FS: OEM Skid Plate
    By darnold87 in forum TW200 Classifieds
    Last Post: 12-07-2012, 05:33 PM
