First oil change. A few questions.
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree25Likes
Thread: First oil change. A few questions.
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    149
    First oil change coming up at 100 miles.
    1 Is the O rings replacement really necessary? I'm asking becaus4 one set of 4 at Procycle seems pretty expensive, but if it needs to be done...
    2 Is anyone using the oil filters from Procycle (pack of five for $34)? I'm assuming they are not reusable.
    Thank you for your help.
    Darth, molson42 and Elvesus like this.
    Member molson42's Avatar
    Sep 2018
    Southern California
    89
    Quote Originally Posted by Cerberus View Post
    Hello and welcome. You don't need to change the orings each time. With a little care they'll last you multiple changes. Do not WD40 the orings though. You'll ruin them.
    The factory filter is reusable, just clean it off and reuse. It should be a fine metal mesh filter. Otherwise the paper media filters should be changed as needed.
    I change my oil every 1,000 miles and change the filter every 2,000. I call it cheap insurance!
    Darth, admiral, goldenhtr and 1 others like this.
    2018 TW200
    2016 Victory Gunner
    Amsoil Dealer of Montclair, CA
    Save up to 25% with a Preferred Customer membership!
    Aug 2018
    San Diego, CA
    149
    Quote Originally Posted by molson42 View Post
    Thank you, I appreciate.
    Tennessee
    1,301
    Make sure any replacement filter has the same four holes as the stock one. Some have been mislabeled before and destroyed engines. Also getting the plug off without stripping it takes some finesse and the right kinda leverage usually. I find pecking at the socket (6pt socket is preferable to 12pt) with a hammer before turning and using a 3/4" breaker bar that's probably 2' long has been the cleanest way so far for me. A shorter bar would probably be doable but the way they pivot is useful here. Using some anti-seize afterwards may be some good insurance as well, but try not to get it in the engine. It's just the large "cap" or lip of the plug where it pushes against the engine, seems to be the heat letting the dissimilar metals kinda adhere to each other. Happens with engine bolts like that sometimes.
    On older TW's, the engine case covers were fastened with Phillips heads that liked to strip rather than turn due to seizure. Had a bear of a time doing a sprocket change on one like that. An impact driver removed one or two but the rest had to be Dremeled down, each one starting to turn after finally getting hot enough. Running the engine until it's warmed up would probably lend a little help to getting the plug to move freely, and hot oil drains out easier.
    admiral and jtstdub like this.
    Aug 2018
    San Diego, CA
    149
    Quote Originally Posted by assquatch20 View Post
    Yes, just ordered the correct filter from Amazon along with a gallon of Yamalube 10-40. I have a breaker bar which pivots and a Toyota 6 side socket from my old 1973 FJ40, I miss that tank. I will warm up the engine of course. I will remove the gear shift just to make sure I have plenty of room to seat the socket correctly. Thank you for all the suggestions.
    Jun 2016
    New Rochelle, New York
    1,803
    It doesn't matter who you ordered the filter from, Amazon, Babbitts, Yamaha itself. Check that those 4 holes are there.
    It's about the wrong product sometimes being found in the right box. This is documented and catastrophic.
    No one at Amazon is going to know the difference. Neither is the kid at the counter at the Yammy dealer.
    I've had my TW for a bit more than 2 years now. Came with the factory metal-mesh filter. I've sprayed it out with contact cleaner and used it again and again.
    Like the other guys I pin it at 1000 miles but if I'm doing really tough riding with her it'll be sooner.
    Fully reusable/not a throwaway filter.
    1995 BMW K75 (Elec Start)
    Aug 2018
    San Diego, CA
    149
    Quote Originally Posted by stagewex View Post
    Yes, it is the filter with four holes, I bought it as a back up. Thank you
    Frosty Hollow
    13,166
    Thought I'd highlight this a bit so others who wander into this thread and post might pick up on it.
    Hailey, ID
    3,405
    If you use 29 ft./lbs. instead of 31 as the torque for the drain bolt you'll never have a problem removing it at the next oil change. I usually use 1,000 to 1,500 miles as a change interval, and if I've been running it hard and hot in the summer or the desert I'll check and clean the oil filter at 500 miles.....probably not necessary but I usually find soft carbon on it and it gives me an idea of whether to change oil at 1,000 or 1,500.
    This was at 30 miles:
    this was at 3,000 miles just after coming back from Death Valley:
    No metal, just carbon.
    I used that same OEM filter from new in 2010 to 16,000 miles in 2017.....probably would last 20 years and 30,000 miles.
    Change again at 500 miles then at 1,000....metal should be minimal by then. Hopefully you have read the thread about using 15% less torque than spec on the filter housing bolts.
    I re-used the filter cap O-ring for at least 10,000 miles and replaced the little one at the Allen bolt about 6,000....it got torn somehow but the replacement still looked fine 10,000 miles later.
    Tweaker likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Jan 2015
    Fair Oaks, Calif
    503
    Bleed valve!!!!!!!!
    Tweaker and admiral like this.
  1. Replies: 15
    Last Post: 02-04-2015, 07:40 PM
  2. First oil change at 100 miles today holy metal shavings
    By Holdnon72 in forum General Discussion
    Last Post: 03-01-2014, 09:57 AM
  3. First oil change, that I've done. Check out my filter
    By Little General in forum Technical Help
    Last Post: 09-14-2013, 11:37 AM
  4. First oil change, now a tapping sound
    By Mac313 in forum Technical Help
    Last Post: 09-11-2013, 10:04 PM
  5. first oil change, quick question
    By russ5415 in forum Technical Help
    Last Post: 02-13-2013, 11:25 PM
